Total acceleration at the bottom of a rolling wheel
A tundra buggy in Churchill, Manitoba, is experiencing issues on slippery ice, with a wheel radius of 0.84 m and a speedometer reading that fluctuates from 0 to 27 km/h over a distance of 7.0 m in 9.0 seconds. The total acceleration at the bottom of the wheel at 4.0 seconds is calculated to be 13.2 m/s², but there is confusion regarding the values for tangential, radial, and linear acceleration. The speedometer measures the angular speed of the wheel rather than the actual vehicle speed, which complicates the calculations. It is noted that the linear acceleration is derived from the radius multiplied by the angular acceleration, but slipping affects this relationship. Understanding the dynamics of rolling with slipping is crucial for accurate calculations.
Angelique
A tundra buggy, which is a bus fitted with oversized wheels, is stuck in Churchill, Manitoba, on slippery ice. The wheel radius is 0.84 m. The speedometer goes from 0 to 27 km/h while the buggy moves a total distance of 7.0 m in 9.0 s.
Find the magnitude of the total acceleration of a point at the bottom of the wheel at the end of 4.0 s.
I know that the total acceleration is the tangential acceleration + the radial acceleration + the linear acceleration. But i can't seem to get the right values for the accelerations since the answer is 13.2m/s^2
for tangential acceleration i got 0.66m/s^2
Im not sure how to find the other 2 accelerations
How do speedos work?
What does the speedo actually measure? (Hint: not the overland speed.)
It measures the speed of the wheel (angular speed) so then the angular acceleration is: (final angular velocity)/time? so 7.5/8 = 0.9375m/s^2? but that seems very small to me because linear acceleration is radius times the angular acceleration. :/
Not when the wheel is slipping on the ice.
The speedo reads the vehicle speed in the event there is no slipping.
So it is calibrated to tell you the tangential speed of the wheel rim.
So the outer edge of the wheel goes from 0 to v in time T, giving an average angular acceleration of ##\alpha_{ave} = v/rT##
... notice that ##a_T=r\alpha=v/T## as expected?
(It is best practice to do the algebra with symbols and substitute the numbers in later.)
Note: that's just an example - you may need to consider more than the average acceleration. i.e. is the acceleration the same throughout the motion? What part does the distance moved play?
I'm guessing you have some notes about rolling with slipping?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
