Total Kinetic Energy: Man, Globe, Platform
The discussion centers on calculating the total kinetic energy of a system involving a man, a globe, and a turntable. The relevant equations for kinetic energy include K = 0.5Mv^2 for the globe and L^2/(2I) for the platform. The user attempts to compute the total kinetic energy, arriving at a value of 3.091 J. There is uncertainty about the correctness of the calculations, particularly regarding the equations used. The consensus suggests that the approach appears correct, providing reassurance to the user.
spirited
A man stands at the center of a turntable that can rotate without friction. He then takes a 1.5 kg globe of the Earth and swings it around his head at the end of a 0.7 m long chain. The world revolves around him every 3.4 s, and the man and the platform have a moment of inertia of 0.5 kgm^2. The angular velocity is 2.71 rad/s in the opposite direction to that of the globe. What is the total Kinetic Energy of the man, the globe, and the platform?
K = 0.5Mv^2 of the globe + L^2/(2I) of the platform
K total = 0.5Mv^2 + L^2/(2I)
K total = 0.5(1.5)(0.7x2pi/3.4)^2 + (0.5x2.71)^2/(2x0.5) = 3.091J
Plz. help... I do not think my answer is right... mainly the equation part...
-Thanks a lot...
Looks right to me.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
