Total phase difference diffraction help
The discussion centers on understanding the total phase difference in diffraction, specifically why the phase angle for the diffracted wave is represented as -k'*r while the incoming wave is k*r. The confusion arises from the geometric interpretation of the phase difference and the application of vector relations. Clarification is provided through the concept of the dot product in vector analysis, which explains the presence of the negative sign. Ultimately, the participant gains clarity on the topic after considering the vector perspective. This highlights the importance of visualizing diffraction phenomena in terms of vectors to grasp phase relationships.
PhysicsGirl90
Hello everybody,
I'm having some trouble comprehending the following image. I am supposed to be able to deduce from the figure that the total difference in phase angle is (k-k')r. To begin with, I do not understand why for the diffracted wave the difference in phase angle is -k'*r while for the incomming wave it is just k*r. Where does the minus sign come from?
Thanks in advance...
Hmm. The picture is a geometric way of showing what is going on and the equation is a way to show it as a vector relation.
So you need to think of the picture in terms of vectors, keeping in mind the definition of the dot product, then you'll see where the minus comes from.
Thanks Bruce, with your hints about the vectors I finally understood where everything comes from.
That's good. You did the work, I just gave you a kick in the right direction ;)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
