How Loud is a Rock Band in Terms of Power Output?
A rock band produces an average sound intensity of 110 dB at a distance of 15 meters from the speakers. The sound is assumed to radiate equally over a hemisphere, leading to a calculated area of approximately 1413 m². Using the intensity formula, the power output can be derived, but the calculations yield results that do not match the provided multiple-choice answers. The discussion highlights the challenges in accurately determining the total power output based on intensity levels. Ultimately, the problem remains unresolved, indicating potential miscalculations or misunderstandings in the application of the relevant equations.
CherryXBOMB
Total Power output Sound!
All right, nevermind, problem resumed.
. A rock band has an average intensity level of 110 dB at a distance of 15 m from the speakers. Assuming the sound is radiated equally over a hemisphere in front of the band, what is the total power output?
Intensity=Power/area
A=4pir^2
Attempt at solution
A=4pi(15)^2
A=2827m^2
2827/2 (hemisphere)
110=p/1413
110x1413=
an answer that is not one of the multiple choice solutions...
A=4pir^2
Attempt at solution
A=4pi(15)^2
A=2827m^2
2827/2 (hemisphere)
110=p/1413
110x1413=
Problem resumed, or problem solved?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
