Touching both terminals of a battery
  • Thread starter Thread starter BogMonkey
    Battery
Touching both terminals of a 9V battery typically does not result in an electric shock due to the high resistance of dry skin, which can be tens of KOhm. Electric shock occurs from current flowing through the body, not merely from the voltage present. For significant current to flow and cause a shock, a higher voltage is needed, especially with dry skin. When skin is wet, resistance decreases, making lower voltages more dangerous. Understanding these principles clarifies why handling low-voltage batteries is generally safe.
BogMonkey
Sorry if this is the wrong forum. When I just touch any part of the metal of both terminals on a 9V battery with a multimeters probes the meter displays the voltage (although it said 20V not 9V for some reason). What I'm wondering is why people don't get electric shocks from touching both terminals of a battery at once. Wouldn't you be completing the circuit?
Try touching it to your tongue.
If you have an old analog meter with a special switch for reading ac volts (e.g. like the Simpson model 260 or the Triplet meter), you do get 2x the actual voltage. The analog meter should be on dc volts for reading batteries. Your skin resistance protects you from shock, up to a limit.
Bob S
Electrical shock is due to current flowing through your body, not so much an electric field (voltage). The resistance of your skin and body allows you to obtain the current by ohm's law (although ohm's law is not strictly valid for a human body, in de sense that the resistance is not independent of the voltage). For a dry skin, this resistance is in the order of tens of KOhm.
You start getting problems with currents from a few mA onwards, which means that you need several tens of volts before things get "shocky".
With a wet or immersed body the resistance lowers and there the limit of "dangerous" voltage is lower (hence the example of the tongue).
See for instance http://hyperphysics.phy-astr.gsu.edu/hbase/electric/shock.html
as a starting point.
Bob S
Ah right that explains it I bought a "household meter" so its probably build for AC.
Thanks. I didn't know skin had such high resistance.
Current gives you the shocks, not voltage. But voltage vill intensify it as it increases.
