Can a Toy Car Run on Only Potential Energy Over an Elliptical Path?
A toy car can theoretically run on potential energy stored in a spring, weight, or flywheel, but it requires an initial impulse to start. The challenge lies in maintaining a path without further inputs while navigating a 50-foot elliptical track. Suggestions include using mechanical guides or electronic systems for path following, though the constraints of the initial impulse and size of the car need clarification. Achieving an elliptical path may be difficult, especially if avoiding electronic signals or mechanical interference. Overall, the design must balance energy storage, path navigation, and the constraints of the project.
bags
Hey guys...
Is it possible to make a car running on only potential energy stored in it,..well the path is supposed to be horizontal & only the initial impulse is allowed.Also the vehicle is supposed to follow a certain path without any inputs while cruising.The path is supposed to be around 50 feet long and elliptical.
Any suggestions are welcome
The power bit is easy. Just use a spring, a falling weight, a flywheel, a rubber band, or if you're feeling sneaky, a battery.
What are your constraints for the path following? You could use an electronic system, - either tracking or with the path pre-programmed, or just a mechanical guide. Let us know more about your task.
I'm not sure I understand that "initial impulse" constraint. Also, what size car are we talking about here? As brewnog implied, you could buy yourself a nice electric car and drive it 100 miles, but I suspect that wouldn't fit with the spirit of what you are trying to do...
Just in case the term 'inputs' includes electronic signals or mechanical interference such as a track, then you might have to work a timed steering mechanism into the design. You could get a circular path by using different sized wheels on each side, but elliptical would be pretty tough. :confused:
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
