Train-hill hp to pull, problem
  • Thread starter Thread starter Ed Boon
    Pull
To determine how many GE locomotives are needed to pull a 15,000-tonne train up a 1-degree grade, the calculations involve understanding the relationship between power, force, and speed. The required force to overcome the grade is approximately 2,565,504 N, while each locomotive provides about 3,281,080 J/s (or 4,400 HP). Assuming a speed of 20 km/h, the potential energy gained per hour is calculated to be around 5.1303 x 10^10 J. Given that one locomotive can produce approximately 1.1811888 x 10^10 J in an hour, it would take about five locomotives to effectively pull the train up the incline. The discussion emphasizes the importance of distinguishing between energy and power in these calculations.
Ed Boon
How many GE locomotives are needed to power a 15k tonne (note tonne not ton) train up a 1 degree grade. Ignore rolling friction and wind resistance. Locomotive traction power is 4400 HP/locomotive.
1 hp = 745.7 J/s * 4400 hp = 3281080 J/s
and the grade force is
m*g*sin(1°)
so
15k (kg) *9.8*sin1=2565504 N
also
I am assuming we need to know how fast they go so just say 15 mph.
(assuming 15 mph could you say at 4400 hp it would require 11816640000 n m/hr)
I am stuck between knowing each train has 3,236,195 W of power and knowing the train will take 2565504 N of force and somereason can't relate them
any help is appriciated
Ed
You need to know a speed - the power depends on how long you take to move a certain distance.
Just think in the upwards direction, how many m/s vertically is 15mph along a 1 deg slope?
Then how much potential energy (mgh) does the train gain per metre?
How many vertical m/s is it moving?
So how many joules/second = watts is this.
(ps pick a set of units to convert everything into)
Before you pick a speed, you might want to check the brake linings.
15Mkg will be challenging to slow from 15m/h.
All the info in the question is typed above, which is why I'm kinda hesitant on some of "assumptions" because isn't it first required to know the speed and acceleration for these? I am aware that coal trains can reach up to 40-50 mph (if what I was reading was correct) so even if it were hard to stop should i still use 15 mph just for the problem's sake?
(decided to use 20km/h for speed) so vertically it would be 20km*cos(1°) = 3.046km = .846 m (in an hour).
pot energy = 15Mkg*9.8*.846 = 124,362,000 kg m^2/s^2 =
(1 J = 1 kg m^2/s^2)
=1.24362 E8 J (required to move over one hour)
1 locomotive = 4400 hp = 3,281,080 J/s * 3600 s/h = 11811888000 = 1.1811888 E10 J/h
is this math right? the j/h of the locomotive seems to be higher so it would just take one?
EDIT*
for pot energy it would be 15Mkg*9.8*(.846m/h*1/3600h/s) = 34545 kg m^2/s^2 = as many joules (1 J = 1 kg m^2/s^2)
so it only needs 34545 J per hour to run? then it would be way under what the train produces, I must be missing something
Is that just the extra energy needed for the slope and I need to include flat land as well?
Do you mean 20km sin(1°) = 349m vertically?
3.046km in 20km is 1:7, steep for a road never mind a train!
ps I would work in m/kg/s to avoid confusion
yes, did it again and got 349m which would put the pot energy at 5.1303E10 J and with one locomotive giving about 1E10 J it would be around 5, which is what the prof said would be around 5-6
thanks
Be careful confusing energy and power. You can only talk about a potential energy change for a certain distance or time and you only have a POWER for the locomotive not an energy.
