Transcendental Retarding Force
  • Thread starter Thread starter bndnchrs
    Force
bndnchrs
A boat with initial speed v[o] is launched, and experiences a retarding force of F = -ae^Bv, where a=alpha=constant and b=beta=constant
Find v(t)
Find Time and Distance for the boat to stop
F=ma
the second part for tmie and distance, I am attempting to solve using mathcad with a perturbative approach incrementing vt o find dv/dt, reinserting v-dv/dt until dv/dt approaches closely to zero. This makes sense, however, only with known values for alpha and beta. I can't really think of a way to formulate v(t).
I retried the problem, and was able to do some integration by treating it as a differentials and deriving a seperable ODE. However, my answers seem very odd. Here's what I did.
m*dv/dt = -\alpha*e^\beta*v
dv/e^\beta*v = -\alpha*dt/m
letting u = e^-Bv
du = -B*e^-Bv
\int1/-B * du = \int-A/m dt
going through all the integration...
we get
v(t)=ln((A*B/m)*(t+constant))/-B
with v(0) = v0
constant = (m/a*B)*e^-Bv0
so... let && = A*B/m
v(t) = ln(&&*t + e^(-B*v0))/-b
which is weird to me, because the higher we set the initial velocity, the slower the speed is after a set t. Someone help!
It isn't wierd, because \beta must be negative, or else the boat would move with negative velocity! :smile:
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
