Transformation of Coordinate Systems
minderbinder
Find a one-to-one C1 mapping [tex]f[/tex] from the first quadrant of the xy-plane to the first quadrant of the uv-plane such that the region where [tex]x^2 \leq y \leq 2x^2[/tex] and [tex]1 \leq xy \leq 3[/tex] is mapped to a rectangle. Compute the Jacobian det Df and the inverse mapping [tex]f^{-1}[/tex].
The hint for the question states: Map all the regions where [tex]ax^2 \leq y \leq bx^2[/tex] and [tex]c \leq xy \leq d[/tex] to rectangles.
I'm a little confused on what they mean by map to a rectangle.
I'm at a loss of where to begin...
Thought about this some more, and I think the solution should be:
(u, v) = f(x, y) = ([tex]\frac{y}{x^2}[/tex], xy)
I checked some coordinates and it appears to work. However, I got this solution through trial and error. Can someone point out to me a way to find the solution in a systematic way?
let's start with the second inequality. xy goes from 1 to 3. this forms one dimension of a rectangle - along the xy-axis. but instead of using an xy-axis, you could use a u-axis or v-axis, if you let u or v equal to xy. Hint hint.
now for the first inequality, if y goes from x^2 and 2x^2, is there a way to manipulate this so that the value of *some algebraic expression* goes from one integer to another? kinda like xy above?
