Transistors and current direction
Current can flow in either direction in BJTs, MOSFETs, and JFETs, but practical considerations limit this. JFETs and MOSFETs are theoretically symmetric, meaning there’s no fundamental difference between drain and source in ideal conditions. However, manufacturers design these devices with specific characteristics that make them asymmetric in practice, affecting performance and breakdown voltage. Operating a BJT in reverse can lead to significantly reduced performance due to its lower beta in the reverse active region. Understanding these nuances is essential for effective device application.
jaydnul
Can current go either direction in a bjt, mosfet, and jfet? Or are they all usually just one direction?
(Especially the jfet. Given the symmetry, I don't see what the difference is between drain and source)
Thanks
The current can go in either direction in any of those devices (by direction, I mean from drain/collector to source/emitter. JFETs and MOSFETS are *in principle* symmetric so there isn't any difference between drain and source in first-order theory. In that sense you're correct. HOWEVER, in practice they are not symmetric. Manufacturers play a lot of tricks to increase the breakdown voltage, improve performance etc (for example look up lightly-doped drain). For this reason you should use the device based on which terminals are labeled drain and source. The take away is that MOSFETs and JFETs that you buy are not symmetric.
For a BJT, while you can operate the device "backwards" keep in mind that performance will be greatly reduced if you do this. Doing so puts the transistor into what is called the "reverse active region" and has much lower beta than the device does in its intended "forward active region".
Hope this clears it up.
Likes jasonRF
Perfect, thanks!
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
