Does a Rod's Size Change When Rotating at the Speed of Light?
  • Thread starter Thread starter captain
    Rod Rotating
captain
if a rod is moving close to the speed of light in its linear velocity and rotating at some angular velocity will the rod's length and width change as it rotates making it look all funky or will it do something else because it can't be treated as a rigid body? If it does do what i mentioned above then its angular momentum is changing and that means there is torque.
Because its endpoints cannot move faster than the speed of light, relative to some external observer (You say it is "moving close to the speed of light". You mean, of course, relative to this observer.) it will appear to bend. As has been said here many times, there is no such thing as a "rigid body" in relativity.
Depends, do you call http://commons.wikimedia.org/wiki/Image:Relativistic_Rolling_Wheel.png" "funky"?
PS I cannot vouch for the accuracy of these pictures, it is a wikipedia link after all, but they seem about right.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
