Rate of Change of Water Level in Triangular Prism
  • Thread starter Thread starter stunner5000pt
    Prism
stunner5000pt
A trinagular prism is 10 m long and has an equilaterlal trinagle for its base. WAter is added at a rate of 2m^3/min. Determine the rate of change of the water level when the water is \sqrt{3} m deep.
ok so the volume of a prism is
V = \frac{1}{2} lwh ... (1)
l is the length
w is the width
h is the height
now dl/dt = 0 because the length of the column of water is constant
to find a relation between h and w i got this because the triangle is an equilaterla triangle
h = \frac{\sqrt{3}}{2} w ... (2)
and it follos that
\frac{dh}{dt} = \frac{\sqrt{3}}{2}\frac{dx}{dt} ... (3)
now subbing 1 into 2
V = \frac{1}{\sqrt{3}} lh^2
\frac{dV}{dt} = \frac{l}{\sqrt{3}} 2h \frac{dh}{dt}
now here's the problem ... what is h??
h does not represent the depth of the water, does it??
it reprsnts the height of the remainder of the prism that has not been filled iwht water. so really
\frac{dh_{water}}{dt} = \frac{dh_{empty part}}{dt}
is it reasonable to say that??
thank you for all your input!
l is the length
w is the width
h is the height
and it follos that
h is the height of the triangle so it is the depth of the water- you triangle has its vertex downward, remember?
ahhh true
the book was rather deceptive in taht it drew the triangle right side up
but that wouldn't make a difference??
Yes, the depth of water is the height of the prism and which is root 3 as given.
I doubt stunner5000pt is still working on this problem after 5 years.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
