Solving Joe's Tricky Boat Problem: Find Boat Speed Relative to Joe
  • Thread starter Thread starter NasuSama
Joe observes a boat moving at a constant speed of 25.2 m/s while Tom runs toward the front of the boat at 2.93 m/s relative to it. To find the boat's speed relative to Joe while Tom is running, the conservation of momentum principle is applied, considering the boat and Tom as an isolated system. Initially, both Tom and the boat are stationary in a chosen frame of reference, which simplifies the calculations. The discussion emphasizes the importance of analyzing the system's momentum before and after Tom starts running to determine the boat's speed relative to Joe accurately. Understanding these dynamics is crucial for solving the problem effectively.
NasuSama
Joe, standing stationary on a beach, sees a small boat of mass M = 179 kg go by at constant speed V = 25.2 m/s. Tom, a man of mass m = 91.8 kg, stands at rest at the back of the boat. Suddenly Tom begins to run toward the front of the boat at speed vrel = 2.93 m/s relative to the boat. Find the speed of the boat v, relative to Joe, while Tom is running.
O.K.
p = mv
MV = MV_F + m(V - V_rel) [I thought that Tom is traveling at V - V_rel velocity]
MV - m(V - V_rel) = MV_F
V_F = MV - m(V - V_rel)/M
...But wrong answer.
Any help?
Start by considering the boat and Tom in isolation. In other words, suppose that the boat and Tom are initially stationary in some frame of reference. Since no external forces act on this isolated system, the center of mass must remain stationary (conservation of momentum).
When Tom begins to run, the center of mass must continue to remain stationary. If that's so, what does that tell you about the sum of the momenta of Tom and the boat in this frame of reference?
I believe that the first time before Tom runs, it's just that m_b * v_b = p_initial [which is the boat's momentum]
Then, I guess that for the second part, we have...
m_b * v_bf + m_t * v_tf
Considering the boat and Tom in isolation, before Tom runs all velocities are zero.
This is a frame of reference specifically chosen such that the boat and Tom are initially at rest. Their motion with respect to the observer on the shore will be considered afterwards. The idea is to separate the effects caused by Tom's interaction with the boat and deal with that first, and then later place those effects into the shore-based observer's frame of reference.
