Trig/constructing sine function from graph
The discussion focuses on deriving a sine function from a given graph with a phase shift of 1 and a period of 6. It clarifies that the actual period is 5, calculated as 6-1. The correct approach involves setting up equations based on the phase shift and period to solve for B and C, leading to the equation A sin((2π/5)x - 2π/5) + D. The poster expresses confusion over their method yielding different results from others, highlighting the importance of accurately interpreting the phase shift and period in sine function construction. The conversation emphasizes the need for careful analysis of the sine graph parameters to derive the correct formula.
Asphyxiated
Construct or "work backwards" from a sine graph to a sine formula. The formula should be in:
y = A sin(Bx+C) +D
Where A is amplitude, D is Vertical Shift (on y access) and Bx+C are arguments of the function
The graph shows that the Phase Shift is 1 and Period is 6 (meaning the basic cycle begins at 1 and ends at 6)
0 <= x <= 2pi (pi as in 3.14..) ("<=" is less than or equal too)
1 <= x <= 6
0 <= x-1 <= 5 /** subtract 1 from all terms **/
0 <= pi(x)-1 <= 5pi /** multiply all terms by pi **/
0 <= (pi(x)-1)/2 <= 5pi/2 /** divide all terms by 2 **/
STUCK
The solution should be in 0 <= Yx+-Z <= 2pi (Where Y and Z can be any integer, the only thing that matters is that the 0 is at the beginning and that 2pi is the end)
________________________________
This is not the only solution I tried, just the last one, so unless I have missed something rather fundamental I can't seem to solve this one. Please note that I solved 14 other problems that were basically of the same thing using the same methods that I have used to try to solve this problem and they all worked out and check out in the answers section (I am not a student, just picking up where I left off in high school).
If I have done something wrong (in the formatting of this posting) or you need something that I neglected to mention just let me know as this is my first time posting anything on this forum.
Also just to clarify all i am looking for is a solution the equalities statement not the whole y = equation as I understand that entirely.
thanks immensely!
y = A sin(Bx+C) +D
Then the period is 6-1= 5, not 6. The "standard" graph goes from 0 to 2\pi and has period 2\pi - 0= 2\pi. Basically, whatever your "Bx+ C" is you must have B(1)+ C= B+ C= 0 and B(6)+ C= 6B+ C= 2\pi. Subtracting the first equation from the second, 6B+ C- (B+ C)= 5B= 2\pi so B= 2\pi/5. Then B+ C= 0 becomes 2\pi/5+ C= 0 so C= -2\pi/5. Your equation should look like A sin((2\pi/5)x- 2\pi/5)+ D or, equivalently, A sin(2\pi/5(x- 1))+ D
1 <= x <= 6
You are going the wrong way here!
STUCK
Why do you say they should be integers?
thanks immensely!
To find the "Bx+ C" for any sine or cosine with a period from x_0 to x_1, Solve Bx_0+ C= 0 and Bx_1+ C= 2\pi.
THANKS!
I looked over the other problems and noticed that they were all with phase shift 0, I don't know how I missed that...
Anyway I appreciate your replies
@HallsOfIvy
I tried it your way and it makes sense but when I solve the equation using period of 5 (6-1) I end with an equation of 0 <= ((pi)x-1)/2 <= 2pi which is markedly different from your procedure and end result. My equation checks out in the answers section, so I guess my question is why did you end up with something different for the same problem?
Since you don't say what you got or what the answer in the book was, I can't answer that.
@HallsOfIvy
I did say what my end result was with "0 <= ((pi)x-1)/2 <= 2pi" but if you want the sine equation it was y = 2 sin(((pi)x-1)/2)
EDIT sorry for all the parentheses, I really need to learn LaTeX
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
