Trig Function Derivation Question
waealu
I am working on some calculus homework and I am stumped by this question. It is in the section "derivatives of trigonometric functions." It seems like it should be easy, but I can't think of where to start. I don't need any answers and you don't need to present any calculations, I only need an idea of where to start. Thank you.
How many tangent lines to the curve y=x/(x+1) pass through the point (1,2)? At which points do these tangent lines touch the curve?
I determined the derivative of the curve to be: 1/(x+1)^2
I began by finding the derivative (as stated above), but I'm not sure where to go next. Thanks.
Let f(x) = x/(x+1). The derivative at x gives you the slope of the tangent line at x. This tangent line passes through the point (x,f(x)), which is enough information to give you the equation of the line. You need to find out when, if ever, it passes through (1,2) as well.
Okay. I've got it. Thanks!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
