Trig/geometry help (triangles/finding sides)
  • Thread starter Thread starter PhizKid
To find side 'R' in the triangle, given L = 6.10 meters, theta = 36.9 degrees, and phi = 53.1 degrees, the Law of Sines can be applied. By drawing a vertical line through the triangle and recognizing that phi is the angle between this vertical line and the triangle's side, the relationship can be established. The equation L/sin(phi + theta) = R/cos(phi) is derived to solve for R. The discussion emphasizes the need to visualize the triangle and apply trigonometric principles correctly. Understanding the relationships between the angles and sides is crucial for finding the unknown side.
PhizKid
Find side 'R'. L = 6.10 meters, theta = 36.9 degrees, and phi = 53.1 degrees.
Pythagorean Theorem
Similar triangles
Law of Sines
Law of Cosines
I don't see any way I can attempt this, I'm very rusty with my trig. We have a known side and a right angle, but I don't see how I can make any other angles (since we only have one side I'm assuming I need to get an angle somewhere
Pythagorean Theorem
Similar triangles
Law of Sines
Law of Cosines
Draw a vertical line through the right side of the length L (the point on the triangle). The length L will be perpendicular to this line, yes? And now take notice that \phi would be the angle between the vertical and the side of the triangle because of the parallel lines rule (the wall is parallel to the vertical line we constructed).
law of sines gives
L/sin(phi+theta)=R/cos(phi)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
