Solve Trig Identities: Match Function to Answer
The discussion revolves around solving a trigonometric identity involving the expression (1-cos^2x)(cscx). Initially, the user attempts to simplify the expression but finds it challenging. They realize that 1 - cos^2(x) equals sin^2(x) and question whether this leads to a simplification involving sine. Other participants confirm the user's reasoning, suggesting that rewriting everything in terms of sine and cosine is a helpful approach. Ultimately, the user successfully simplifies the expression to sin(x), validating their solution.
Cephalopod
Hi, I'm confused about using trig identities.
Match the trigonometric function with one of the following: (a) -1, (b) cos(x), (c) cotx (d) 1, (e) -tan(x), (f) sin(x)
(1-cos^2x)(cscx)
None that I know of.
I multiply it through, which gives me:
csc(x) - cos^2(x)(cscx)
I divide out csc(x) which gives me:
csc(x)(1 - cos^2(x)(1))
(got me nowhere really)
edit: I just realized that I can do
1-cos^2(x)=sin^2(x)
edit2: am I wrong in thinking that since cosecant is the reciprocal of sine, that in csc(sin^2x) one sine cancels out, leaving me with sin(x)?
I might of just solved my own problem :P can anybody confirm? Thanks
Yes, that looks right. Good job.
My first thought with something like that would be to write everything in terms of sine and cosine. Here csc(x)= 1/sin(x) so that problem is (1- cos2(x)/sin(x)= 1/sin(x)- cos2(x)/sin(x). But cos2(x)= 1- sin2(x) so that second fraction is (1- sin2(x))/sin(x)= 1/sin(x)- sin(x).
1/sin(x)- cos2(x)/sin(x)= 1/sin(x)- 1/sin(x)+ sin(x)= sin(x), just as you say.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
