How do I solve this challenging trigonometric integral?
  • Thread starter Thread starter cuttlefish
    Integral Trig
cuttlefish
\int \frac{3cosx-10sinx}{10cosx+3sinx} from -pi/3 to pi/3
some sort of identity maybe?
well...I made the mistake of saying the answer was zero since it's an odd function (yes, i know this is ridiculously not right) and so incurred the wrath of my calculus teacher. if someone can help me get started on this then maybe I can salvage something resembling a grade.
you could try writing
10 = A.cos(\alpha)
3 = A.sin(\alpha)
for unknown A & alpha, plug this into your equation then make use of some tirg identities for angle sums...
maybe not that exactly... but something along those lines has a good chance of working
lanedance had the start of this idea. Let's see if I can finish it off. First off, notice that the same two numbers appear: 3 and 10. If you square them, add them, and take the square root, you get sqrt(109). This will enter into things in a little while.
1. For the numerator, you have 3cos(x) - 10 sin(x). If this were sinA*cosx - cosA * sinx, you could rewrite this as sin(A - x).
2. Simililarly, you have 10cos(x) + 3sin(x) in the denominator. If this were cosA*cos(x) + sinA*sin(x), you could rewrite it as cos(A - x).
The trouble is, there is no A for which cosA = 10 or for which sinA = 3. This is where sqrt(109) comes in. Multiply the numerator and denominator of your integrand by 1 in the form of (1/sqrt(109))/(1/sqrt(109)).
The numerator now looks like 3/sqrt(109) * cos(x) - 10/sqrt(109)* sin(x). The denominator now looks like 10/sqrt(109) * cos(x) + 3/sqrt(109) * sin(x). So sinA = 3/sqrt(109) and cosA = 10/sqrt(109), and these should hold for both the numerator and denominator.
With this work, you can rewrite the integrand as sin(A - x)/cos(A - x), which is tan(A - x), which is easy enough to integrate. You'll need to find A, of course, which can be done by using the appropriate inverse functions in either sinA = 3/sqrt(109) or cosA = 10/sqrt(109).
wow, thanks you guys. this is definitely something that I never would have done. we spent like two seconds on product sum rules and I didn't really understand that they could be used like this. i'll need to write this down and stare at it for a couple minutes but thanks! I sense a passing grade in my future.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
