It would really help if you provided more detail on what exactly you did and fixed typos and errors in what you write before posting it. We can't read your mind, so we can only go by what appears here. When there are numerous typos, it's difficult to figure out what you actually meant and what was just a careless mistake. Frankly, it's kind of annoying to have to try figure out what you did or what you mean because you're not willing to put the effort into expressing yourself clearly.
For example, you wrote
Ayesh said:
\intcos2x/\2sqrt{1+sin^2x}
Obviously, there's an error in the LaTeX code you wrote as the radical sign didn't appear correctly. What's less obvious is that you had a factor of 2 in front of the square root that didn't show up because of that error. The only reason I found this out was because the LaTeX appeared when I happened to hover the pointer over that part of the post.
\int1-sin2x/2\sqrt{1+sin^2x}
In this line, you fixed the LaTeX, and the two now appears. From our standpoint, the two just appeared mysteriously, and we wonder what exactly you did to get that two. So we can guess you did a substitution, replacing the dx by du which resulted in the two, but how are we supposed to know that? You didn't say what substitution you used, and you omitted any mention of dx and du in the integral. It could have just as easily been an algebra error, a mistaken trig identity, etc.
Finally, you need to follow the normal conventions of mathematics, particularly the use of parentheses. Without having seen where your second line came from, some would interpret your second line to mean
1-\frac{\sin^2 x}{2}\sqrt{1+\sin^2 x}
whereas you really (I think) meant
\frac{1-\sin^2 x}{2\sqrt{1+\sin^2 x}}
Writing (1-sin
2 x)/(2 sqrt(1+sin
2 x)) would have accurately conveyed your intent.
I hope you realize I'm not posting here just to criticize you or give you a hard time. In one sense, I just want you to be able to use this forum effectively. In a broader sense, I'm hoping you will understand how essential it is to be able to express your ideas accurately and clearly.
