Trig integrals and finding volume.
MarcL
Find the volume obtained by rotating the following curves bounded by:
y=sinx y=0 pi/2≤ x ≤ pi
I know I have to use the cylindrial disk method so ∫2pi(x)f(x)dx.
I did the following ∫(pi/2 to pi) 2pi (x) sinxdx
I factor out the 2pi and I am left with ∫(x)(sinx)(dx) always from pi/2 to pi
I then used integration by part with u=x du=dx and dv=sinx v=-cosx
therefore uv -∫vdu --> -(xcos(x)) (from pi/2 to pi) - ∫-cos(x)dx from pi/2 to pi
However my answer key shows a completely different work / answer.. I don't know how to approach the question differently
Which axis are you rotating about?
Also if this is about the x-axis, all you have to do is use:
\int_a^b \pi f(x)^{2}dx
Wait but I thought a cylindrical would be 2pi(x) f(x) dx . X for the radius and f(x) for the height. And yes it was about the x-axis
What's the area of a disk?
It would be pi (x)^2. And this was a stupid question. I meant cylindrical shell... So my teacher used the disk method. How would I be able to decide between cylindrical shell, the disk and washer method :/ ( I mean washer there would have to be a "hole" of some sort no?)
Nope you can use the shell or disk method anytime, sometimes (like exams) there is only one way to do it because the other way will make the integral really nasty.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
