Trig Problem: Finding Principle Values of x
  • Thread starter Thread starter WillyTech
    Principle Trig
The discussion revolves around solving the trigonometric equation 2sin²x - 1 = 0 for different ranges of x. For part a, the principal values of x are derived, with the correct solution being x = 45° and x = 135° for part b, which considers the range 0° ≤ x ≤ 180°. The participant struggles with part c, which requires finding all values of x, noting that sine is periodic with a period of 360°. Clarifications are made regarding the correct notation and methodology for solving the equation. The participant acknowledges mistakes and expresses a willingness to review the material.
WillyTech
I have a trig problem that i need help with. I have done a) & b) but not c) because i don't get it.
Solve the following for:
a) principle values of x
b) 0°≤x≥180°
c) all values of x
1. 2sin²x-1=0
my work:
1a. principle values of x
sinx(2sin)-1 = 0
sinx(2sin)=1
sinx=1
(2sin/2)=
sin=½
1b. 0°≤x≥180°
sin1/2=±√1-cosx/2
2sin²x-1=0
2sin²x=1
2sin(sinx)=1
2sin/2=1/2
sin=1/2
sin½= 30°,90°
1c. all values of x
Your initial working should be the same for all 3 parts, it's just the difference in the range of x for each part that results in you having different answers.
In your working, you wrote:
2sin²x-1=0
sinx(2sinx)=1 **
sinx=1 or 2sinx=1
sinx=1 or sinx=0.5
This does not seem right! You can only use this method if the right hand side of equation ** equals zero. Can you think of another way to do this? Note that there is only 1 sinx term in the original equation.
Also, do you know what the principal region for sinx is? For part b, I believe the range should be 0°≤x≤180°. And finally, for part c, you need to find a general solution which can "generate" all the possible values of x.
Please also take note of your expressions. For your working in part b, expressions like "2sin(sinx)=1" and "sin½= 30°,90°" don't seem very right.
b) 0°≤x≥180°
c) all values of x
1. 2sin²x-1=0
my work:
sinx(2sin)-1 = 0
sinx(2sin)=1
Please, please, please, learn to write exactly what you mean! I have no idea what "sinx(2sin)" could mean! If you don't want to use Tex or html codes, you could just say sin^2(x)= 1.
<b> <u>sinx=1</u></b>
<br /> Okay, this at least makes sense but I don&#039;t see where you got it from<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> (2sin/2)= <br /> <b> <u>sin=½</u></b> </div> </div> </blockquote> sine is a <b>function</b>! It makes no sense to say &quot;2sin/2&quot; or <br /> &quot;sin= 1/2&quot;.<br /> sin(x)= 1/2. But you still haven&#039;t answered the question. What is x?<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> 1b. 0°≤x≥180°<br /> <br /> sin1/2=±√1-cosx/2<br /> 2sin²x-1=0<br /> 2sin²x=1<br /> 2sin(sinx)=1<br /> 2sin/2=1/2<br /> sin=1/2 </div> </div> </blockquote>I have absolutely no idea what you are doing here!<br /> The &quot;principal&quot; value is the single value of x between -\frac{\pi}{2} and \frac{\pi}{2} that gives sin(x)= 1/2. Since that is positive, yes, x must be positive. You still haven&#039;t said what that is. You can&#039;t do (b) until you have done (a). <br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> <u><b>sin½= 30°,90°</b></u> </div> </div> </blockquote>Once again, makes no sense! According to my calculator, sin(1/2 (radian))= 0.47942553860420300027328793521557. If you mean arcsin(1/2) or <br /> sin<sup>-1</sup>(1/2), say so! In any case, sin(90°)= 1, not 1/2.<br /> However, you want 2sin<sup>2</sup>(x)- 1= 0 or sin(x)= \frac{1}{\sqrt{2}}. My calculator gives, as principal value (part (a) again!), x= 45°. You should know that sin(180°- x)= sin(x) so the other value, in 0\le x \le 180 is 180- 45= 135°.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> 1c. all values of x<br /> ? </div> </div> </blockquote> sine is periodic with period 360°. Take the two values you got for x between 0 and 180° (the only two solution between 0 and 360°) and add 360n to them.
OOPS! i guest i made a lot of mistakes.:frown:
ill go back over my work and reread the chapter, and thanks for checking my answers.
oh yeah, and it was 0≤x≤180...... i am really sorry i mistyped it.:frown:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
