Trig problems (relating to FBD)
  • Thread starter Thread starter mujadeo
    Fbd Trig
The discussion revolves around the application of trigonometry in analyzing forces acting on a car being towed up an incline at a 20-degree angle with no friction. The user struggles with understanding why the weight's y-component is expressed as -w * cos(theta) in the context of their free body diagram (FBD). They correctly identify the weight vector's relationship with the axes but are confused about the designation of sides in their triangle. Clarification is provided that the incline should be treated as the x-axis, with the y-axis perpendicular to it, which alters the interpretation of the components. Understanding this orientation is crucial for correctly applying trigonometric principles to solve the problem.
mujadeo
Car being towed up incline. It makes 20deg angle to the horizontal. Goes at constant velocity. No friction. Tow rope rated at 6000N max..
will it break?
I don't need help in whole question, its just the trig which i keep getting wrong. (i have taken trig).
The answer is actually worked out in book but i don't understand why the trig is as it is.
So in my FBD i orientate axis so that normal force points along pos y-axis, tension points along pos x-axis.
I know that if incline angle is 20deg, then the angle weight makes with neg y-axis will also be 20deg
The book says that wsuby = -w cos theta.
This is messing me up on a lot of problems so here's what I understand, in very basic trig terms:
The weight vector, neg y-axis and horizontal make up a triangle.
Theta is the angle (20deg) between the neg y-axis and the weight.
Therefore weight is the adgacent side
Neg y-axis is the Hyp side
the horizontal is the opposite side (to the angle).
So, ,based on the triangle i have chosen, the y-component of the weight = the hyp side of the triangle and the adjacent side is the weight vector.
To sum up, I have the adjacent, and the angle, and I want the hyp.
So, according to trig, because cos theta = adj / hyp,
then hyp = adj / cos theta.
So why does the book say that the y component of the weight is -w * cos theta?
Thanks for any help.
Why do you say that the weight is the adjacent side? And that the y-axis is the hypotenuse? Draw your diagram again.
Along an inclined plane, the incline is the x-axis and the y-axis is perpendicular to it.
