Finding the Values of (Theta): Solving cos2theta = 1/4
  • Thread starter Thread starter ibysaiyan
    Theta
To solve the equation cos(2θ) = 1/4 within the interval 0° ≤ θ ≤ 180°, it is suggested to first sketch a graph of the function to visualize potential solutions. The graph will indicate two possible values for θ. After identifying these points, a calculator can be used to find the precise values. The answers should be rounded to the nearest integers. This approach combines graphical analysis with numerical calculation for an effective solution.
ibysaiyan
Find the values of (theta),in the interval 0degree\leq(theta)\leq180,for which cos2theta=1/4.Give your answers correct to the nearest integers.
:s
do i just tap them in the calculator or how?
I would start by sketching a graph of the function first. You should be able to see that there are two possible values of theta. Then sure, use your calculator to find them.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
