Trig substitution help (easy one )
The discussion revolves around solving the integral ∫_{0}^{5} \frac{dt}{(25 + t^2)^2} using trigonometric substitution. The initial poster attempts to simplify the integral but realizes they made an error in their calculations. They are guided to use the substitution t = 5tan(θ), which leads to a more manageable form of the integral. After further calculations, they find that the integral can be expressed using the power-reducing formula for cos²(θ). Ultimately, they identify their mistake and confirm the correct approach to solving the integral.
RadiationX
Use trig substitution to find \int_{0}^{5} \frac{dt}{25 + x^2}dt
I can solve it to here \int_{0}^{\frac{\pi}{4}}\frac{25sec^2\theta}{(25 + tan^2\theta)^2}
and from this point i can factor the denominator into {625(1+ \tan^2\theta)}^2
which becomes 625\sec^4\theta
now i have the integral \int_{0}^{\frac{\pi}{4}}\frac{25sec^2\theta}{625\sec^4\theta}
this now reduces to \int_{0}^{\frac{\pi}{4}}\frac{cos^2\theta}{25}
and at this point i can use a power reducing formula to get rid of the \cos^2\theta
assuming that the last integral is correct and that i use the power reducing formula to reduce \cos^2\theta correctly, what am i doing wrong?
i have a TI-89 graphing calculator, and when i integrat this problem on it i get a different answer than when i do it by hand. where is my mistake?
this post is incorrect look further down for the correction.
i'm really sorry about this.
You can use the double angle formula for cos 2x to get rid of cos^2 x. cos 2x = 2cos^2 x - 1.
As the integral stands now, you could use another formula to find the answer, but in order to put the integral into a form where you can use a trig substution you have to play around with it:
25 + t^2 = (\sqrt{25 + t^2})^2
So the integral becomes:
\int_{0}^{5}\frac{dt}{(\sqrt{25 + t^2})^2}
Make the substutions:
t = 5 \tan{\theta}
dt = 5 \sec^2{\theta} d\theta
and work it from there. :)
This is actually a standard integral. Anyways, you seem to have made a few errors. Here we want
\int_0^5 \frac{dt}{25 + t^2}
let t = 5\tan{\theta} \Longrightarrow dt = 5 \sec^2{\theta} and note that t=5 \Longrightarrow 5 = 5\tan{\theta} \Longrightarrow \theta = \pi / 4. Thus we just have
\int_0^{\frac{\pi}{4}} \frac{5\sec^2 \theta}{25 + (5 \tan \theta)^2} \ d\theta
= \frac{1}{5}\int_0^{\frac{\pi}{4}} \frac{\sec^2 \theta}{1 + \tan^2 \theta} \ d\theta
now, review your trig identities and see if you can find an easy way to do this :smile:
The standard integral is
\int \frac{dx}{a^2+x^2} = \frac{1}{a}\arctan\left(\frac{x}{a}\right) \ + \ C,
by the way.
I made a huge mistake in my original post! the first integral is
\int_{0}^{5} \frac{dt}{(25 + x^2)^2}dt
and what follows is what i get. I'm really sorry about posting this problem incorrectly.
i'm putting this back to the top because i screwed it up the first time.
No problem :smile:
Anyways, in that case your work is almost right. We want
\int_0^5 \frac{dx}{(25+x^2)^2}
substitute x = 5\tan \theta \Longrightarrow dx = 5\sec^2 \theta \ d\theta and so x=5 \Longrightarrow \theta = \pi / 4. Thus our integral is the same as
\int_0^{\frac{\pi}{4}} \frac{5\sec^2 \theta}{(25 + 25\tan^2 \theta)^2} \ d\theta
= \frac{1}{125}\int_0^{\frac{\pi}{4}} \frac{\sec^2 \theta}{\sec^4 \theta} \ d\theta
= \frac{1}{125}\int_0^{\frac{\pi}{4}} \cos^2 \theta \ d\theta
Data said:
No problem :smile:
i worked this down to exactly the same thing that you did but when i use my
TI-89 graphing calculator to integrate this i get a different answer than what i get by hand.
\frac{1}{125}\int_0^{\frac{\pi}{4}} \cos^2 \theta d\theta
= \frac{1}{125} \int_0^{\frac{\pi}{4}} \frac{1}{2} \left(1 + \cos (2\theta)) \ d\theta
= \frac{1}{250}\left[\theta + \frac{\sin (2\theta)}{2} \right]_0^{\frac{\pi}{4}}
= \frac{1}{250}\left(\frac{\pi}{4} + \frac{1}{2}\right).
now i see my mistake. thankyou Data
