Why Does Trig Substitution Yield Different Integral Results?
Jrlinton
∫8cos^3(2θ)sin(2θ)dθ
rewrote the integral as:
8∫(1-sin^2(2θ))sin(2θ)cos(2θ)dθ
u substitution with u=sin(2θ) du=2cos(2θ)dθ
4∫(1-u^2)u du= 4∫u-u^3 du
4(u^2/2-u^4/4)+C
undo substitution and simplify
2sin^2(2θ)-sin^4(2θ)+C
The book gives an answer of:
-cos^4(2θ)+C
4(u^2/2-u^4/4)+C
-cos^4(2θ)+C
Check your answer by differentiating it to see if you get back to ##8 \cos^3 (2 \theta) \sin (2 \theta)##. Checking your answer by differentiation is something you should always do, every time.
I do in fact get my original expression. Thanks.
There's no need to rewrite the integral. In the original integral, use ordinary substitution with ##u = \cos(2\theta)##, and ##du = -2\sin(2\theta)d\theta##. Using this substitution leads directly to the book's answer.
4(u^2/2-u^4/4)+C
-cos^4(2θ)+C
I second Ray's advice to always check your answer by differentiation.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
