Trigonometric Equation: Solving for Theta with Quadratic Formula
The discussion revolves around solving a trigonometric equation for theta using the quadratic formula. The equation can be rewritten to incorporate tangent and secant functions, leading to a quadratic form. Participants suggest substituting cos(theta) with a variable, but caution that this may result in a fourth-degree equation instead of a quadratic. Simplifying the trigonometric terms using double angle formulas is proposed as a potential method to make the equation more manageable. Overall, the conversation highlights various approaches to tackling the complex trigonometric equation.
ThomasMagnus
Solve for \theta
20= 32[sin\theta] (72/32[cos\theta]) + 1/2(-9.8){(72/32[cos\theta]}2I'm really having trouble with this question. I've tried it many times, but keep getting stuck.
Is there anyway to let X=72/32[cos\theta] and then solve for x with the quadratic equation?
Can someone help me with this one? Thanks!
20= 32[sinLaTeX Code: \\theta ] (72/32[cosLaTeX Code: \\theta ]) + 1/2(-9.8){(72/32[cosLaTeX Code: \\theta ]}2
The above equation can be written as
20 = 72*tanθ + 1/2*(-9.8)(72/32)^2(sec^2θ)
20 = 72*tanθ + 1/2*(-9.8)(72/32)^2(1 + tan^2θ)
Now simplify the above equation and solve the quadratic to find tanθ.
Where did those fractions (tangent and secant) come from? I read it as
20= 72sin(\theta)cos(\theta)-(4.9)\left(\frac{9}{4}\right)^2cos^2(\theta)
ThomasMagnus, if you do replace cos(\theta) with "x", you will have to replace sin(\theta) with \sqrt{1- x^2} and you will eventually have a fourth degree equation, not quadratic. But that might be the only way to do it.
So, the equation in question is
<br /> 20= 72sin(\theta)cos(\theta)-(4.9)\left(\frac{9}{4}\right)^2cos^2(\theta)<br />
Would it help if we simplified the trig terms by way of double angle formulae?
For instance,
<br /> 2sin(\theta)cos(\theta)= sin(2\theta)<br />
<br /> 2cos^2(\theta)-1= cos(2\theta)<br />
could be used, which would make the equation look something like this:
<br /> 20=36sin(2\theta)-(9.8)\left(\frac{9}{4}\right)^2cos(2\theta)+1<br />
Just throwing some things out there that could possibly help =)
y = vo*sin(θ)*t - 1/2*g(t^2)
And t = x/(vo*cosθ). Put it in the above equation.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
