Can the set of x be found for -1 ≤ 1/(1+cosx) ≤ 1?
The discussion revolves around solving the inequality -1 ≤ 1/(1+cosx) ≤ 1. It is established that cosx cannot equal -1, leading to the conclusion that -1 < cosx < 1, which results in 1/(1+cosx) being between 0.5 and infinity. Participants suggest using trigonometric identities to further analyze the inequality. The reciprocal of the expression indicates that it must be either greater than 1 or less than -1, depending on its positivity or negativity. The conversation emphasizes the need for a deeper understanding of trigonometric functions to find the solution set for x.
IsrTor
solve the inequality:
-1\leq 1/(1+cosx) \leq1
firstly cosx does not equal -1 but you'll see doesn't help much
-1<cosx<1
0<cosx+1<2
that makes the above equation 1/(1+cosx) between 0.5 and infinity. but I have no clue as to how to find the set of x which solve the inequality
Hi IsrTor! :smile:
You need to learn your trigonometric identities …
what does 1 + cosx also equal? :wink:
-1<cosx<1
0<cosx+1<2
Since 1/(1 + cosx) is between -1 and 1, its reciprocal has to be larger than 1 or smaller than -1, depending on whether 1/(1 + cos x) is positive or negative, respectively.
Can you do something with that?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
