Can the set of x be found for -1 ≤ 1/(1+cosx) ≤ 1?
In summary, the given inequality can be rewritten as -1 < 1/(1 + cosx) < 1. By using the reciprocal property, we know that the set of x which solve the inequality will be either larger than 1 or smaller than -1, depending on the sign of 1/(1 + cosx).
IsrTor
solve the inequality:
-1[tex]\leq[/tex] 1[tex]/[/tex](1+cosx) [tex]\leq[/tex]1
firstly cosx does not equal -1 but you'll see doesn't help much
-1<cosx<1
0<cosx+1<2
that makes the above equation 1/(1+cosx) between 0.5 and infinity. but I have no clue as to how to find the set of x which solve the inequality
Hi IsrTor! :smile:
You need to learn your trigonometric identities …
what does 1 + cosx also equal? :wink:
-1<cosx<1
0<cosx+1<2
Since 1/(1 + cosx) is between -1 and 1, its reciprocal has to be larger than 1 or smaller than -1, depending on whether 1/(1 + cos x) is positive or negative, respectively.
Can you do something with that?
What is a Trigonometric Inequality?
A trigonometric inequality is an inequality that involves trigonometric functions, such as sine, cosine, and tangent. It compares two expressions containing trigonometric functions and uses the symbols <, >, ≤, or ≥ to show the relationship between the two expressions.
How do you solve a Trigonometric Inequality?
To solve a trigonometric inequality, you must isolate the trigonometric function on one side of the inequality and use algebraic techniques to simplify the expression. Then, you can use the unit circle or a graphing calculator to determine the values of the trigonometric functions that satisfy the inequality.
What are the common mistakes when solving Trigonometric Inequalities?
Some common mistakes when solving trigonometric inequalities include forgetting to consider the period of the trigonometric function, using the wrong inequality symbol when simplifying the expression, and forgetting to check for extraneous solutions. It is important to carefully follow the steps and double-check your work to avoid these mistakes.
Why are Trigonometric Inequalities important in mathematics?
Trigonometric inequalities are important in mathematics because they allow us to analyze and solve problems involving angles and triangles. They also have applications in fields such as physics, engineering, and astronomy. Understanding trigonometric inequalities is essential for students who plan to pursue higher-level math and science courses.
What are some real-life examples of Trigonometric Inequalities?
Trigonometric inequalities can be used to solve problems involving angles and distances, such as finding the maximum height of a roller coaster or the minimum length of a ladder needed to reach a certain height. They are also used in navigation and surveying to calculate distances and angles. Additionally, trigonometric inequalities are used in physics to model and analyze the motion of objects.
  • Precalculus Mathematics Homework Help
33K
