Proving Cosine Inequality with Triangles
In summary, the homework statement asks if cosine of an angle is greater than or equal to three/two. If A=B=C=\frac{\pi}{3}, then cosine of the angle is greater than or equal to three/two. If A,B,C can be swapped without changing the equation, then any extremum has the same A,B, and C. There are no boundary solutions and cosine of an angle is greater than or equal to three/two.
Saitama
4,243
93
If ##A+B+C=\pi##, prove that ##\cos A+\cos B+\cos C \leq 3/2##.
I don't really know how to start. ##A+B=\pi-C##. Taking cos on both sides doesn't seem of much help. I need a few hints to start with.
Taylor series expansion?
What?
This is basic trigonometry and I don't think I need to use calculus here.
Hmm how about ##A = B = C = \frac{\pi}{3}##.
So that ##cos(A) + cos(B) + cos(C) = \frac{3}{2}##
I am not allowed to do that. I have to prove it in a proper way instead of substituting the values.
That's a tough one then. Wolfram gives :
cos(A+B+C)
= cos(A)cos(B)cos(C) - sin(A)sin(B)cos(C) - sin(A)cos(B)sin(C) - cos(A)sin(B)sin(C)
= cos(A)[cos(B)cos(C) - sin(B)sin(C)] - sin(A)[sin(B)cos(C) - sin(C)cos(B)]
= cos(A)[cos(B+C)] - sin(A)[sin(B-C)]
cos(A+B+C)
That's already in my notes. I am sure that I don't have to use this.
I've found a way to do this using calculus knowledge. I don't see an easier way.
Start by assuming that we are talking about angles in triangle, so A,B,C are in the range [0,π]. Find the stationary points and show that all are ≤ 3/2. Include an argument that you have found all the stationary points.
Sorry but I haven't done calculus problems involving three variables.
Meanwhile, I was trying this. From the AM-GM inequality,
[tex]\frac{\cos^2(A/2)+\cos^2(B/2)}{2} \geq \cos(A/2)\cos(B/2)[/tex]
[tex]\Rightarrow \cos^2(A/2)+\cos^2(B/2) \geq \cos\left(\frac{A+B}{2}\right)+\cos\left(\frac{A-B}{2}\right)[/tex]
Now I can covert A/2 and B/2 to A and B on LHS but at RHS, the term ##\cos\left(\frac{A-B}{2}\right)## troubles me. I can rewrite ##\cos\left(\frac{A+B}{2}\right)=\sin(C/2)##, add ##\cos C## on both the sides and make a perfect square at RHS plus some constant but the term ##\cos\left(\frac{A-B}{2}\right)## is a problem here.
Here's a hint. On the interval 0 < theta < 90*, cos(x) is a concave function.
That means that if I pick a cos(A) and a cos(B), the midpoint of these points has a y value of
(cos(A)+cos(B))/2
Then that is going to be less than cos(x) at that same point on the x axis.
cos((A+B)/2)
Unless of course, that midpoint is the point itself, or A=B
I'll have to think of a way to do this outside of the 90* interval, but I bet some sort of comparison can be made considering that the sum of cosines will have one negative term.
Hi Pranav! :wink:
Since A, B, and C can be swapped without changing the equation, any extremum will have equal A, B, and C.
Or rather, A, B, and C will be equal modulo ##2\pi##, since the cosine has a period of ##2\pi##.
So we have:
\begin{array}{lcl}
A+B+C=\pi & \quad & (1)\\
A \equiv B \equiv C \pmod{2\pi} && (2)
\end{array}
Substituing (2) in (1) gives:
\begin{array}{lcl}
3A &\equiv& \pi \pmod{2\pi} \\
3A &=& \pi + 2\pi k \\
A &=& \frac \pi 3 + \frac{2\pi}3 k \\
A &\equiv& \pm \frac \pi 3, \pm \pi \pmod{2\pi}
\end{array}
When enumerating the possible solutions, we find 2 relevant and distinct solutions:
\begin{array}{lcl}
A=B=C=\frac \pi 3 & \quad & \cos(A)+\cos(B)+\cos(C) = \frac 3 2 \\
A=B=\pi,\ C=-\pi && \cos(A)+\cos(B)+\cos(C) = -3
\end{array}
Since there are no boundary solutions we can conclude for this continuous function that:
$$-3 \le \cos(A)+\cos(B)+\cos(C) \le \frac 3 2$$
Alternatively, we can find the same result with the method of Lagrange multipliers.
But then, you didn't want to use calculus. :smile:
Likes 1 person
Sorry to hijack, but I didn't know we could conclude that. Could you explain this idea?
I like Serena said:
Hi Pranav! :wink:
You already know that I am not familiar with modular arithmetic. :rolleyes:
Anyways, I asked my teacher about this. He told me to consider three points on the graph of y=cos x ##(A,\cos A), (B,\cos B)## and ##(C,\cos C)## and work on the centroid of the triangle formed.
Centroid is ##\left(\frac{A+B+C}{3},\frac{\cos A+\cos B+\cos C}{3}\right)##. The ordinate on the graph of y=cos x corresponding to the abcissa of centroid is ##\cos\left(\frac{A+B+C}{3}\right)=3/2##. Since ordinate of centroid of is less than or equal to 3/2, the inequality is proved. I guess this is enough for the question.
Yes, your teacher's method is exactly what I was getting at earlier. Since the midpoint of (A, cos A), (B, cos B) and the midpoint of (B, cos B), (C, cos B) and the midpoint of (A, cos B), (C, cos C) are always under the graph of cos(x) at those same points, then so is the center of the triangle. The only way it matches cos(x) is if the center of the triangle reduces to be cos(x), which happens when A=B=C.
Pranav-Arora said:
The ordinate on the graph of y=cos x corresponding to the abcissa of centroid is [itex]\cos\left(\frac{A+B+C}{3}\right)=3/2[/itex].
I think you mean 1/2 here. But It looks like you understand the answer. It is quite a nice solution really.
What is a trigonometric inequality?
A trigonometric inequality is an inequality that involves trigonometric functions, such as sine, cosine, tangent, and their inverses. These inequalities are typically used to solve equations involving triangles or circular functions.
What are some common trigonometric inequalities?
Some common trigonometric inequalities include the triangle inequality, which states that the length of any side of a triangle must be less than the sum of the lengths of the other two sides, and the Cauchy-Schwarz inequality, which states that the dot product of two vectors is less than or equal to the product of their magnitudes.
How do you solve a trigonometric inequality?
To solve a trigonometric inequality, you must isolate the trigonometric function on one side of the inequality sign and use algebraic or trigonometric identities to simplify the expression. Then, you can use the properties of inequalities to find the range of values that satisfy the inequality.
What is the difference between an equality and an inequality?
An equality is a statement that two expressions are equal, while an inequality is a statement that two expressions are not equal. Inequalities involve symbols such as <, >, ≤, and ≥ to compare the expressions, while equalities use the = symbol.
How are trigonometric inequalities used in real life?
Trigonometric inequalities are used in various fields such as engineering, physics, and navigation. They can be used to solve problems involving triangles, such as finding the maximum or minimum height of a building, or to analyze the behavior of waves and oscillations. They are also used in GPS systems to calculate distances and angles between locations.
