DM said:
How would you, to the best of your abilities, explain to someone like me how trigonometry functions emerged? I'm not in any way or form an advanced mathematics student and in this specific subject I only know the basics of the very basics (i.e how to find the sides and angles of right triangles). I should also inform you that I have already researched in wikipedia and many other web sources. To my discontent appreciation, none of the websites have presented me with straight forward answers. Hence why I choose to finally succumb and consult the professionals of this magnificent website.
Not only do I very politely beg you to provide me with web links that concerns about the history of trigonometry functions but also, and more importantly should I mention, how the
values of each individual trigonometry function was devised.
Thanking you in advance
Trig functions led to some other important math functions, as well.
If you know your sum and difference theorems, you might realize that trig tables could be used to solve difficult multiplication problems. If you had the values for the sine and cosine of every angle from 0 to 90 degrees in a table, you could look up one of the numbers you wanted to multiply in the sine column, the other in the cosine column, and use the trig table to reduce your difficult multiplication problem into a simple addition and subtraction problem.
For example:
sin(A)*cos(B) = (1/2)sin(A+B) + (1/2)sin(A-B)
Thus to multiply 173.65*9.9027, you look up in tables and find
0.17365 = sin(10), 0.99027 = cos(8) and the above formula gives:
sin(10)*cos(8) = (1/2)(sin(18) + sin(2))
From tables, sin(18) = 0.30902 sin(2) = 0.03490
sin(18) + sin(2) = 0.34392 and
(1/2)(sin(18)+sin(2)) = 0.17196
Giving 0.17365*0.99027 = 0.17196
You have to mentally keep track of the fact that 173.65 equals .17365 x 10^3 and that 9.9027 equals .99027 x 10^1. You add your powers of ten and realize that your final answer has to be .17196 x 10^4, or 1719.6
Eventually, John Napier took this a step further and developed "logarithms". Same basic principle: http://www-groups.dcs.st-and.ac.uk/~history/Mathematicians/Napier.html. Napier's logarithms weren't to any base, but Henry Briggs worked with Napier to eventually develop base 10 logarithm of
e and eventually Nicolaus Mercator developed a table of base e logarithms.
William Oughtred used the relationship of logarithms and numbers and used them to create a couple of sliding scales. Now instead of having to carry around a table of trig values or logarithms, you carry them on a couple of sticks that were rigged so that one stick could slide back and forth - the first slide rule, which was an extremely powerful calculating device that was popular for 340+ years - until the first "electronic slide rule" was developed.
Note: there's a difference between a calculator, which traditionally was used for mechanical devices that could add and subtract, and a slide rule, which could do much more advanced jobs, such as multiplication, subtraction, powers, roots, solve quadratic equations, solve complex number problems, etc. Seeing as how most people only need a 'calculator' capable of balancing a checkbook, the term 'calculator' has come to describe even the more advanced electronic calculating devices.
