Trigonometry - How to solve this equation and find the solutions.
  • Thread starter Thread starter mirandab17
    Trigonometry
To solve the equation sin^2x = sinx cosx for 0 < x < 2pi, the first step is to rearrange it to sin^2x - sinx cosx = 0 and factor it to sinx(sinx - cosx) = 0. This gives solutions of sinx = 0 at x = 0 and x = pi. For the second factor, sinx - cosx = 0 leads to sinx = cosx, which occurs at x = pi/4 and x = 5pi/4. The complete set of exact solutions is therefore 0, pi/4, pi, and 5pi/4.
mirandab17
Solve: sin^2x = (sinx)(cosx)
0 < x < 2pi
Find exact solutions.
Okay, so I got 0, pi/4, but just wasn't sure how to do this...
I know you bring the sinxcosx to the other side, making it
sin^2x - sinxcosx = 0
...and then I tried factoring out sinx leaving me with sinx(sinx - cosx). That's where I got lost. So sinx is 0 at 0 and pi on the unit circle, so two solutions are 0 and pi, but what on Earth do I do with sinx - cosx? That's when I started thinking about possible other identities that could help me out, but each left me with more craziness on my page!
0 < x < 2pi
\sin x(\sin x - \cos x) = 0
If a*b=0 then either a = 0 OR b = 0 (or both can be zero).
You've covered the first part (equating \sin x to zero) and found all the solutions).
For the second part, equate \sin x - \cos x = 0.
The easiest way to go from here is to divide throughout by \cos x then rearrange the equation. But take care that by doing this, you're disallowing solutions that make \cos x = 0 (because then you'd be dividing by 0). So check that none of those satisfy the original equation.
EDIT: In this case, it's not strictly necessary to do this (the check I mentioned), but it's good practice when an equation is solved by cancelling out factors from both sides (rather than factorising the entire expression).
Another way to solve
  cos(x) - sin(x) = 0
is to multiply both sides by cos(x) + sin(x). Then recognize the identity for cos(2x). With this method you have to check for extraneous solutions.
(Next someone will suggest the exact way to solve this.)
Well, OK, if you twist my arm. :biggrin:
\sin x - \cos x = 0 \Rightarrow \sqrt{2}\sin(x - \frac{\pi}{4}) = 0 \Rightarrow \sin(x - \frac{\pi}{4}) = 0
The equation sinx-cosx =0 is equivalent with sinx=cosx. There are two angles between 0 and 2pi having equal sine and cosine.
ehild
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
