Trigonometry: Solving for Cosine Using Segment Angle and Triangle Properties
  • Thread starter Thread starter S_BX
    Angle Trig
The discussion revolves around finding cos(BETA) using properties of a triangle and a segment of a circle. The user initially struggles with the formula cos(BETA) = (L^2 - 4h^2)/(L^2 + 4h^2) and seeks assistance in deriving it. Participants suggest using the Pythagorean Theorem to determine the third side of the triangle, which is defined as R-h. After some back-and-forth on the calculations, the user ultimately figures out the solution independently. The thread highlights the complexities of trigonometric relationships in geometric contexts.
S_BX
Hi,
I have a segment of a circle, and know the following quantities.
I need to find cos(BETA), and I know that it's supposed to be = (L^2 - 4h^2)/(L^2 + 4h^2), and I've been trying this for hours.. I suppose it has something to do with the triangle - as you can find the 3rd side (=radius-h), but I just can't get it.. Can somebody please help me out?
http://www.stevenbetts.btinternet.co.uk/bangle.gif
You could use the Pythagorean Theorem to find the 3rd side. But, there is too much information, so \cos\beta can be expressed many ways.
I just took the 3rd side to be R-h.
Could you show me how you came up with
\frac {L^2 + 4h^2} {8h} for the hypotenuse. Why not just call it what it is R?
Because the 1st part of the question asked me to show that R = that. I got it by Pythagoras theorem...
R^2 = (L/2)^2 + (R-h)^2 (pythag)
R^2 = L^2/4 + R^2 - 2hR + h^2 (expand square terms)
2hR = L^2/4 + h^2 (gather like terms)
8hR = L^2 + 4h^2 (multiply through by 4)
R = (L^2 + 4h^2)/8h (rearrange for R)
The second part of the question is to find cos(BETA) where beta is the half angle, using the above result, and I'm totally stuck on that part.
Solved
Never mind guys - I got it eventually! :) Thanks for trying to help though! :)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
