Triple Integral moment of inertia
Punkyc7
set up a triple integral for the moment of inertia Iz for the region inside the sphere
x^2+y^2+z^2=4a^2 and inside the cylinder
x^2+y^2-2ax=0
so I draw my picture and convert to cylindrical coord. and i get an integral from 0 to sqrt(4a^2-r^2)
an integral from 0 to 2acostheta and an integral from 0 to 2pi
then I multiply by 2 becuase its only the top part of the volume that i set up and the integral is integrating r^3
my question is the answer says that the theta limits and goes from 0 to pi , so why is that?
Is theta the polar angle? If so, the polar angle can't go above 180 degrees. (If it did, it would wrap around to the other side of the sphere, and we would just use a different phi to denote that.)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
