Triple Integrals: Solving \int\int\int^{}_{B} ye^(-xy) dV
The problem involves evaluating the triple integral \(\int\int\int_{B} ye^{-xy} dV\) over a specified box region defined by \(0 \leq x \leq 4\), \(0 \leq y \leq 1\), and \(0 \leq z \leq 5\). Participants are exploring the integration process and addressing issues that arise during their calculations.
  • Mixed
  • Participants discuss different approaches to integrating the function, including switching the order of integration and the implications of their choices. There are attempts to simplify the integral and concerns about the correctness of the results obtained after integration.
Some participants have provided insights into the integration process, while others express confusion regarding their results and the implications of their calculations. There is an acknowledgment of mistakes made during the calculations, but no consensus has been reached on the correct approach or solution.
Participants are grappling with the limits of integration and the behavior of the function at specific points, particularly regarding the logarithmic term that arises in the calculations. There is also a focus on ensuring proper notation and clarity in the mathematical expressions used.
shards5
[tex]\int\int\int^{}_{B} ye^(-xy) dV[/tex] where B is the box determined by 0 \leq x \leq 4, 0 \leq y \leq 1, 0 \leq z \leq 5.
[tex]\int^{4}_{0}\int^{1}_{0}\int^{5}_{0} ye^(-xy) dzdydx[/tex]
Integrating the first time I get
zye-xy
Plugging in 5 and 0 I get
5ye-xy
Integrating the above with respect to y. I use u = 5y and dv = e-xy which gives me du = 5du and v = [tex]\frac{-e^(-xy)}{x}[/tex]
Which leaves me with the following equation.
-5y*[tex]\frac{e^(-xy)}{x}[/tex] - [tex]\int e^(-xy)5du[/tex]
After integration I get
-5y*[tex]\frac{e^(-xy)}{x}[/tex] + [tex]\frac{5e^(-xy)}{x}[/tex]
Plugging in 1 and 0 into the above I get
-5[tex]\frac{e^(-x)}{x}[/tex] + 5[tex]\frac{e^(-x)}{x}[/tex] - 5[tex]\frac{e^0}{x}[/tex]
Which just leaves me with since the first two cancel each other out.
-5[tex]\frac{e^0}{x}[/tex]
Integrating the above I get
-5log(x) which is where my problem lies, I can't get the log of 0.
Let's fix up the latex a little. For exponents, use e^{-xy} instead of e^(-xy).
[tex]\int\int\int^{}_{B} ye^{-xy} dV[/tex] where B is the box determined by [tex]0 \leq x \leq 4, 0 \leq y \leq 1, 0 \leq z \leq 5[/tex].
[tex]\int_0^4 \int_0^ 1 \int_0^5 ye^{-xy} dzdydx[/tex]
[tex]= \int_0^4 \int_0^1 \Bigr|_0^5 zye^{-xy} dzdydx[/tex]
[tex]= \int_0^4 \int_0^1 5ye^{-xy} dydx[/tex]
At this point, I think it would be simpler to integrate with respect to x.
Didn't even think about that . . .but for some reason it doesn't seem to be working.
I switched the integration around and got the following.
[tex]\int_0^1 \int_0^4 5ye^{-xy} dxdy[/tex]
After the first integration it comes out really neatly as
-5e-xy
and after plugging in 0 and 4 I get
-5e-4y
5/4e-4y
but after plugging in 0 and 1 I get the wrong answer, not sure what I am doing wrong.
-5e-xy
-5e-4y
[tex]5 e^{-(0)(y)}[/tex] isn't zero.
I guess I shouldn't have rushed through the calculations as I did, thanks a lot for pointing out my mistake.
  • · Replies 105 ·
12K
  • · Replies 27 ·
  • · Replies 22 ·
