Triple Integration: Solve Homework Equation
The discussion revolves around a triple integration problem in spherical coordinates, specifically focusing on determining the correct parameters and limits for integration. The original poster is attempting to solve a problem involving the integration of a function over a spherical volume.
  • Participants discuss the conversion of Cartesian coordinates to spherical coordinates and the appropriate differential volume element. There are questions about the limits of integration for the variables involved and whether the correct coordinate system is being used.
Participants are actively exploring the setup of the problem, with some providing guidance on the limits for spherical coordinates. There is a mix of understanding and confusion, particularly regarding the angles and their definitions in spherical coordinates.
Some participants express uncertainty about the definitions of the angles involved and the correct limits for integration, indicating that this may be their first encounter with spherical coordinates. There is also mention of a hemisphere as the boundary condition for the integration.
Quatros
I'm trying to figure out the other parameters to solve the problem
I know sqrt(x^2+y^2+z^2) = p
I changed the integrand to p^3 sin(theta) since p * p^2 sin(theta)
Then for the first integration sign, I know how to get the rest of them.
The differential volume ## dV=r^2 \, \sin{ \theta} \, dr \, d \theta \, d \phi ## in spherical coordinates. You need to integrate the function over this and pick the limits on ## r ##, ## \theta ##, and ## \phi ## correctly.
but isn't that cylinderical cordinates.
No. Cylindrical coordinates is like polar coordinates in two dimensions and also has a ## dz ##.
Charles Link said:
The problem asks for spherical coordinates. Read it carefully.
It's p for sphere our in our book, unless you aren't talking about integrand.
You can call it ## p ## or ## \rho ## or ## r ##, just so that you are consistent.
Alright, I changed
Sqrt[x^2+y^2+z^2] to p * p^2 * sin(theta)
Would the z= sqrt(4-x^2+y^2) turn into sqrt(4-p^2)?
Where is the ## dp ##, ## d \theta ## , and ## d \phi ##? Also, what do the limits need to be on ## p ##, ## \theta ##, and ## \phi ##? If you know how spherical coordinates work, the answer is simple. Incidentally, I think the book is using the Greek letter "rho"=##\rho ##, but it's easier to use ## r ##.
P 0 to sqrt(4-p^2)
Theta from 0 to 2pi?
the other symbol from 2 to 2?
The boundary of the surface you should recognize as a hemisphere of radius ##r=2 ##. It is very easy to write the limits for it in spherical coordinates=Suggestion is you google "spherical coordinates" and study the explanation.
yeah, I did that and still confused. Sorry about my bad english.
## \phi ## is the azimuth angle. It is the same angle as the ## \phi ## in cylindrical coordinates. The ## \theta ## is the tricky one in polar coordinates. It is measured from the z-axis. In the entire sphere, ## \theta ## goes from 0 to ## \pi ##. For a hemisphere, it goes from ## 0 ## to ## \pi/2 ##. Polar coordinates is much easier explained holding a pencil and showing where it points. It's much easier to describe in person than in a write-up on the internet. But anyway, if you start with the pencil pointing upward, along the z-axis, that is ## \theta =0 ##. Tilt the pencil down slightly, and you tilt it down by angle ## \theta ##. Depending on the direction you tilt it, that defines the ## \phi ## angle...Rotate the tilted pencil (and yourself) around the z-axis (i.e. turn to the left or right), and ## \theta ## stays constant, but you change ## \phi ##.
Is this graph an Ice cream com
This is an ice cream cone, so the ball part (theta) is going from 0 to 2pi , P/R: 0 to 2,
The third parameter is giving me trouble.
Quatros said:
Is this graph an Ice cream comThis is an ice cream cone, so the ball part (theta) is going from 0 to 2pi , P/R: 0 to 2,
(Referring to the hemisphere that is the boundary), ## \phi ## goes from ## 0 ## to ## 2 \pi ## (## 360^o ##). The polar angle ## \theta ##, goes from ## 0 ## to ## \pi/2 ## (## 90^o ##). It's probably not obvious if this is the first time you used spherical coordinates, but with a little practice, it gets easier.
Is 8 pi correct?
Quatros said:
Is 8 pi correct?
Yes, that's what I get also.
