Troubles with a Dynamics exercise
  • Thread starter Thread starter Felafel
    Dynamics Exercise
The discussion revolves around solving a dynamics problem involving two carts pushed by an external force. Initially, the user incorrectly applied Newton's laws, leading to an erroneous calculation of the forces between the carts. After clarification, they correctly determined the acceleration of the system as 2 m/s² and recalculated the forces, concluding that the force exerted by cart 2 on cart 1 is -4 N, and by cart 1 on cart 2 is 4 N, in accordance with Newton's third law. The final solution aligns with the principles of dynamics, confirming the calculations are now accurate. The importance of free-body diagrams and proper application of Newton's laws was emphasized throughout the discussion.
Felafel
Two carts (1&2) on a flat surface, are pushed by an external force (##\vec{F}##), exerted on 1 (the carts are motionless and touching each other).
Consider the two objects as particles and take no notice of any friction.
F=12N; mass of 1 (##m_1##)=4,0 kg; mass of 2 (##m_2##)= 2,0 kg.
Find the intensity and the direction of the force exerted by 1 on 2 (##\vec{F_{12}}##) and the force exerted by 2 on 1 (##\vec{F_{21}}##)
I tried solving the system given by:
##\vec{F_{12}}=\vec{F} - \vec{F_{21}}## and ##\vec{F_{21}}= m_2 * a##
obtaining:
##m_1 * a = 12 - m_2 *a## ##\Rightarrow## ##a=2,0 m/s^2##
and thus:
##\vec{F_{21}}=2,0kg * (-2,0 m/s^2)=-4 N## with the minus sign, as this force is opposite to F
##\Rightarrow## ##\vec{F_{12}}=16N##
which, according to my textbook is not the right result.
I don't get where are the mistakes, though. Can anyone help me please?
Your first equations are not right - you're mixing forces acting on different objects.
You need to draw some free-body diagrams and then apply Newton 2 to them.
What will be the relation between the 2 forces you're asked to find?
This violates Newton's 3rd law.
allright, should it be like this then?
i find the acceleration, which is:
##a=\frac{\vec{F}}{m_1+m_2}## = ##2 m/s^2##
in the free-body diagram of 1 there is ##\vec{F_{21}}##
so I multiply the acceleration for ##m_2##, which gives ##\vec{F_{21}}=-4N## (because its direction is opposite to that of the x-axis)
and, for Newton 3, there must be an equal and opposite force, which means ##\vec{F_{12}}=4N##
Yes, this looks right :)
You can check the answer by seeing that the resultant force on m1 is therefore 8N which agrees with its acceleration.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
