Troubleshooting Electromagnet Design for Telegraph Key and Sounder
  • Thread starter Thread starter Cspeed
    Electromagnet
The discussion focuses on troubleshooting a telegraph key and sounder design that utilizes a ferromagnetic nail as an electromagnet. The creator is struggling to generate sufficient magnetic attraction with their current setup, using either AA or D batteries, and is not achieving the desired sound effect. Suggestions include increasing the number of wire turns on the nail, using a higher voltage power source, and considering alternative ferromagnetic materials like screws for better performance. The importance of using appropriate magnet wire and ensuring a good magnetic circuit is emphasized, with a recommendation to explore a horseshoe magnet design for improved results. Implementing these changes is expected to enhance the functionality of the telegraph sounder.
Cspeed
I'm trying to build a telegraph key and sounder. The sounder that I have designed (well, saw online) is a metal nail (which is ferromagnetic) with at least several dozen (maybe 200+) turns of wire around it. When a current is on the wire, the nail should become an electromagnet, and then pull down some kind of ferromagnetic metal strip, creating a sound. Upon being released, the strip bounces back up (maybe using a rubber band) to clang against something else.
My issue: Using either two AA batteries or two D batteries, I can't get the nail to attract much of anything, not even close to making a sound. I haven't found a good metal strip yet, but even paper clips barely get attracted to the nail. If a compass is close enough, it will detect the magnetic field. Any suggestions? Is it possible that the nail isn't very ferromagnetic, or is there something better to use? Thanks for any help.
You need either more turns or more current. Try a 6V lantern battery or a 12 V Pb-acid alarm battery.
You might increase the diameter of your core. Try a screw, for example, maybe 1/4-20 x 2", wrapped with 1 layer of electrical tape so the threads don't bite into the wire. Are you using small gauge (around 24 AWG) magnet wire? (Magnet wire has a clear coating instead of thick plastic insulation, so you can wind many turns in a small radius.) Two dozen turns won't do the job--try hundreds. You should get action!
I probably have 100-200 turns of 28 AWG, insulated. Does the length of the nail matter? It's about 0.5 cm diameter, 6cm length.
Here is a nice telegraph sounder design:
http://www.sfu.ca/~achanne/projects/Telegraph%20Sounder/
There are two solenoid coils wound around small bolts, with a piece of iron connecting the bottoms of the two bolts, to create a horseshoe electromagnet. This horseshoe magnet design with two coils is a much better magnetic circuit than a single nail.
Wow, that's a great guide. I'll go ahead and try that out then.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
