True or false eigenvalue problem
achuthan1988
Q)Different eigenvectors corresponding to an eigenvalue of a matrix must be linearly dependant?
Is the above statement true or false.Give reasons.
What did you try already?? If we know what you tried then we'll know where to help??
Begin by looking at some examples of matrices. Pick some arbitrary (easy) matrices and calculate its eigenvectors.
I would NOT look at specific matrices. This can be done better more abstractly.
Suppose u and v are non-zero eigenvectors, for linear operator A, corresponding to distinct eigenvalues \lambda_1 and \lambda_2 respectively. Then Au= \lambda_1 u and Av= \lambda_2 v.
Suppose they are not independent. Then v= \mu u for some non-zero scalar \mu. That gives Av= \mu Au or \lambda_1 v= \mu \lambda_2 v so that v= (\mu \lambda_2)/\lambda_1)u.
But that means (\mu \lambda_2)/\lambda_1= \mu so that \lambda_2= \lambda_1, a contradiction.
(Of course, this requires \lambda_1\ne 0 so we can divide by it. If \lambda_1= 0, just reverse the \lambda_1 and \lambda_2. They cannot both be 0 because they are distinct.)
Now, can you extend that to any number of independent eigenvectors?
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
