Trying to find dispersion relation
autobot.d
\imath\frac{\partial u}{\partial t} + \frac{\partial^2 u}{\partial x^2}=0
\left(x,t\right) = \int^{\infty}_{-\infty}A\left(k\right)e^{\imath\left(kx-wt\right)}dk
u\left(x,0\right)=\delta\left(x\right)
Not sure how to get w(k)
A\left(k\right) = \frac{1}{2\pi}\int^{\infty}_{-\infty}\delta\left(x\right)e^{-\imath\left(kx\right)}dx = \frac{1}{2\pi}
plugging this into u(x,t) do I work with
u\left(x,t\right) =\frac{1}{2\pi}\int^{\infty}_{-\infty}e^{\imath\left(kx-wt\right)}dk
This is where I am stuck. I know w(k) is the dispersion relation. If I put in the pde do I just deal with
\imath \left(-\imath w\right) + \frac{d^{2}u}{dt^{2}} = w +\frac{d^{2}u}{dt^{2}}=0
Not sure if this is what I even want to do. Any guidance would be appreciated.
I was making the problem too hard on myself. I got
w=k^2
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
