Two infinite sheets of different charge density
The discussion focuses on calculating the electric field generated by two infinite sheets with charge densities σa and -σb using Gauss's law. The electric field outside the plates is determined to be E = σ(a-b)/2ε0 n, while the field between the plates is E = σ(a+b)/2ε0 n. The principle of superposition is applied to find the resultant electric field in different regions: left of the plates, between the plates, and right of the plates. The correct expressions for the electric field in these regions are confirmed as E = -σ(a-b)/2ε0 n, E = σ(a+b)/2ε0 n, and E = σ(a-b)/2ε0 n, respectively.
  • Understanding of Gauss's law in electrostatics
  • Familiarity with electric field concepts and charge density
  • Knowledge of vector notation and unit vectors
  • Basic principles of superposition in electric fields
  • Study the derivation of electric fields from infinite charged sheets using Gauss's law
  • Explore the principle of superposition in electrostatics
  • Learn about the implications of charge density on electric field strength
  • Investigate applications of electric fields in capacitor design and behavior
Students studying electromagnetism, physics educators, and anyone interested in understanding electric fields generated by charged surfaces.
purplegreen
From the picture attached it can be seen that there are two plates with charge density σa and -σb. We will chose → as the n direction.
What is that electric field everywhere for this system?
∫∫E.dS = ∫∫σ/ε0 dA
Using Gauss' law we can take three gaussian surfaces. One containing both of the plates and two more containing each individual plate.
Using the surface containing both plates, we have:
ESn + ESn = σ(a-b)/ε0 n
hence,
E = σ(a-b)/2ε0 n outside of the plates
Inside I think I should use superposition of the two other surfaces. However I'm not sure which direction the electric field goes in for these two surfaces?
Generally I'm not convinced by my answer and lack some understanding which I would like some help with. Thanks in advance!
Using Gauss's Lw, you should be able to show that an infinite charged sheet creates a homogeneous electric field directed perpendicularly to the sheet:
[tex] \vec{E} = \frac{\sigma}{2 \epsilon_0} \, \hat{n}[/tex]
where [itex]\hat{n}[/itex] is a unit normal directed from the sheet outwards (on each side).
Now you can use the principle of superposition to find the electric field due to two sheets of charge.
Ok so would the answers for this question be:
on the left hand side of the 2 plates:
E= -σ(a-b)/2ε n
In the middle of the plates:
E= σ(a+b)/2ε n
Finally, on the right hand side of the plates:
E= σ(a-b)/2ε n
Thanks for the help.
  • · Replies 26 ·
  • · Replies 18 ·
