Two Masses in Pulley System (Rotational Dynamics)
The discussion revolves around solving a rotational dynamics problem involving two masses connected by a cord over a frictionless pulley. The user struggles with calculating the tensions in the cord segments and the overall acceleration of the system. Initial attempts to derive equations for torque and acceleration yield incorrect results, leading to confusion about the setup of the problem. Clarifications are provided regarding the forces acting on the masses and the role of gravitational force in the calculations. Ultimately, the user resolves the issue and receives a suggestion for a quicker method to verify their final figures.
S-Flo
So I've been prepping for my Engineering Physics 1 final, and I've been having trouble with rotational motion problems, but this problem has been driving me crazy for the past two days:
(I wanted to include a normal link to an image, but I'm a new member, so here's something)
i.imgur.com/wHAG3.jpg
There are two masses, one on top of a frictionless tabletop (12.0 kg), and one hanging off the edge of the table (5.00 kg), both are connected by an ideal cord wrapped around a frictionless pulley with a radius of 0.26 m and a mass of 2.10 kg. What are the respective tensions of the horizontal and vertical segments of the cord?
Known variables:
mass on top of table = 12.0 kg
mass hanging off edge = 5.00 kg
radius of pully = 0.26 m
mass of pully = 2.10 kg
Unknowns:
Horizontal Tension
Vertical Tension
I = 1/2*m*r2 (moment of intertia)
τ = I*αθ (Torque, and that's angular acceleration on the right)
Krot = 1/2*I*ω2 (rotational kinetic energy)
F = m*a
I first attempted to find the torque on the disk and translate that into tangential force on the mass on the table. After that failed I thought that the acceleration for everything in the system should be the same and tried to make acceleration equations for the two masses and the pulley and solve with algebra. Both gave me incorrect answers. I'm not sure whether I'm approaching this incorrectly or if the equations I set up were wrong.
Thanks in advance!
Welcome to PF!
Hi S-Flo! Welcome to PF! :wink:
S-Flo said:
… I thought that the acceleration for everything in the system should be the same and tried to make acceleration equations for the two masses and the pulley and solve with algebra.
That should work.
Show us your full calculations, and then we'll see what went wrong. :smile:
Here's what I tried:
F = ma; so a = F/m
τ = rF = Iaθ; and aθ = ratan;
τ = Iratan; atan = τ/Ir = rF/Ir = F/I
and F should be the force the hanging box exerts on the pully (F = mg), so:
atan = Fg/I
So, if a is the same for all parts of the system, then:
Th/12 = Tv/5 = Fg/I
But Fg = 49.05 and I = 0.07098 which would make atan = 691 m/s2, which is very obviously wrong. And after that, I've had no idea what to do.
Hi S-Flo! :smile:
S-Flo said:
aθ = ratan
Noooo :redface:
raθ = atan
(it might be easier if you use the standard notation of α for angular acceleration :wink:)
tiny-tim said:
Hi S-Flo! :smile:
Noooo :redface:
raθ = atan
Even then the acceleration comes out to 39.8 m/s2, and the answer is still wrong. I think my whole system is set up incorrectly.
I can't follow your equations.
For example, where is the 5g ? :confused:
It's 5 kg, and it's one of the values given in the initial problem.
Honestly, I don't even know what going on in this problem anymore, and I don't see the point in playing with my setup, since it's obviously wrong.
no, the gravitational force, 5g
I thought that was the force of gravity acting on the 5 kg box. F = ma, so 5g = 49.05
I also thought that was the force acting on the pulley to create torque.
No, Tv - Th is the force creating the torque.
And Tv and 5g are the forces acting on the hanging mass.
That explains part of my error, but even then I still can't see how to set this system up.
Wait, never mind. I just figured out the problem. Thanks.
:smile:
now that you've solved it, here's a "cheat" method that's quicker …
(they probably wouldn't like you using it in an exam, but it's still useful as a check on your final figures :wink:)
replace the pulley by an ordinary object of "rolling mass" I/r2
then the total mass is 12 + I/r2 + 5 = 12 + 2.1/2*0.262 + 5,
the net force is 5g, so the acceleration is 5g/(12 + 2.1/2*0.262 + 5)
does that give you the right result?​
