Two particles and magnetic field
Two charged particles, A and B, enter a magnetic field at right angles with the same velocity. Particle A has charge q and mass m, while particle B has charge -q and mass 2m. Both particles experience the same force magnitude due to their equal charge, but they circulate in opposite directions because of their differing masses. As a result, particle A has a gyroradius that is half that of particle B. The discussion concludes that the differences in their motion stem from their mass and acceleration under the same force.
kimberlyann9
Two particles, 'A' with charge and mass of q and m and 'B' with charge and mass of -q and 2m, each enter at right angles to a uniform magnetic field with the same velocity. Compare the circular paths that each begin upon entering the magnetic field.
A) A experiences the same force magnitude as that of B and circulates in the same direction as B with A's radius equal to that of B.
B) B experiences twice force magnitude as that of A and circulates in the opposite direction as A with A's radius at half that of B.
C) B experiences twice force magnitude as that of A and circulates in the opposite direction as A with A's radius equal to that of B.
D) A experiences the same force magnitude as that of B and circulates in the opposite direction as B with A's radius at half that of B.
Bvq=mv^2/r
Since the magnetic field is uniform, B can be disregarded. So can v since it is the same velocity for both particles. So the equation can be reduced to q=m/r, and to rearrange and solve for r, r=m/q. Then I plugged in m and q for both particles and I get A=m/q and B=-2m/q. So B circulates the in opposite direction as A, and A has half the radius as B, so that narrows it down to B and D. I'm a little stuck on the force. Does B experience twice the force magnitude as A because B=2m while A=m?
The gyroradius equation comes straight from the Lorentz force law,
\vec{F} = q \vec{v}\times\vec{B}.
So, what can you conclude about the relative forces?
They both have the same force magnitude because they both have q for the charge.
Exactly. They simply have different motions because they have different masses, and therefore different accelerations when subjected to the same force.
Thanks!
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
