Two Problems Dealing With Circular Motion
The discussion focuses on two problems related to circular motion. The first problem involves calculating the angle in radians that a wheel rotates in 1.0 second, with participants struggling to arrive at the correct answer of 5.65 radians. The second problem addresses the banking angle required for a highway curve with a radius of 127 m, ensuring a car traveling at 27.5 m/s does not skid, emphasizing the need to consider centripetal acceleration and the forces acting on the car. Participants express confusion over the necessary formulas and calculations for both problems. Clarification on the correct approach and formulas is sought to resolve these issues effectively.
wetcarpet
1) A wheel is rotating at a rate of 2.7 revolutions every 3.0 s. Through what angle, in radians, does the wheel rotate in 1.0 s?
I tried to solve this problem by:
{a} 360 x 2.7 = 972
{b} 972 / 3 = 324
{c} 364 / (180 / Pi) = 5.65
Yet, 5.65 is not the answer. The rust coated around the section of my brain labeled 'Trigonometry' is probably the culprit here.
2) A highway curve has a radius of 127 m. At what angle should the road be banked so that a car traveling at 27.5 m/s has no tendency to skid sideways on the road? [Hint: No tendency to skid means the frictional force is zero.]
I have no train of logic on this problem because I'm utterly spellbound. I feel as if perhaps I'm minus an essential formula, though.
Any suggestions or advice would be a godsend.
I get 5.65 too.
I think it is.
No tendency to skid means that a frictional force is not required to keep the car from sliding.
The car is centripetally accelerating. Consider Newton's 2nd law. (What forces act on the car?) Hint: The vertical components of the forces must add to zero.
You're quoting two different numbers for the number of degrees per second, pick one!
