Two Pulleys with two acceleration and two tensions (Diagram included)
The discussion revolves around a physics problem involving two masses connected by strings and pulleys, where the goal is to calculate the tensions (T1 and T2) and accelerations of the blocks. The coefficient of friction between the upper block and the table is 0.32, and the user has derived initial equations but is unsure about their approach. Key equations include the relationships between tensions and accelerations, with suggestions made to substitute variables to simplify the problem. The user received guidance on how to proceed with the calculations by eliminating variables. This collaborative effort aims to clarify the solution process for the given physics scenario.
Wara
pulley
Two masses are attached together by means of light inextensible strings and light frictionless pulleys as shown in the diagram. The system is released and the upper block slides along the table. The coefficient of friction between this block and the table is 0.32. Calculate the magnitude of the tensions (T1 and T2) and accelerations while the blocks are acceleration.
http://content.screencast.com/users/Waraa/folders/Snagit/media/bc6a12fc-dd79-4db6-91a4-1057f75aca6e/03.10.2012-15.11.45.png
(1) m1a1 = T1 - μmg
(2) m2aa = m2g - T2
(3) 2T1 = T2
(4) 2a2 = a1
T1 = 113.7N
T2 = 196N
(1) + (2) + (3) + (4)
m1a1 + m2aa + 2T1 + 2a2 = T1 - μmg + m2g - T2 + T2 + a1
2a2 = T1 - μmg + m2g + a1
I'm stuck right there. Am I even doing it right?
(1) m1a1 = T1 - μmg
(2) m2aa = m2g - T2
(3) 2T1 = T2
(4) 2a2 = a1
T1 = 113.7N
T2 = 196N
Hi Wara! :wink:
Wara said:
(1) m1a1 = T1 - μmg
(2) m2aa = m2g - T2
(3) 2T1 = T2
(4) 2a2 = a1
Fine so far! :smile:
ok, now you should substitute for a2 and T2 from (3) and (4) into (2):
(1) m1a1 = T1 - μmg
(2) m2a1/2 = m2g - 2T1
then eliminate T1 :wink:
tiny-tim said:
Hi Wara! :wink:
(1) m1a1 = T1 - μmg
Thank you so much.
