Two questions regarding integrating items
  • Thread starter Thread starter TFM
    Integrating
TFM
I have a couple of questions about some intriguing looking equations.
Firstly, I have to integrate:
\frac{sin\theta}{cos\theta} d\theta
Is there an answer to just dividing them? because sin/cos = tan, but that doesn't seem to help?
Secondly, I have to integrate:
6e^{-x^2}
This One > 6e^{-x^2} Should be displaying e to the minus x sqaured
but I didn't think you could integrate a e^{x^2}
Again, this one V
e^{x^2} ?
\frac{sin\theta}{cos\theta} = tan\theta
Given above
Any help would be most appreciated,
TFM
\int \frac{sin\theta}{cos\theta}d\theta
if you let u=cos\theta, what is \frac{du}{d\theta}?
For the 2nd one, I don't think you can express that in terms of elementary functions.
\frac{du}{d\theta} = -sin\theta
Is there any way to integrate this, or should I leav it as it is (The question is solving differential equations)
TFM
and so -du=sin\theta d\theta.
Now just sub this into the integral and you can get it out.
I have to admit making a small mistake...
The equation to solve is:
\frac{cos\theta}{tan\theta}
TFM
then you need to put tan as sin/cos and get
\frac{cos^2 \theta}{sin\theta}
which in this case put u=sin
So:
u = sin\theta
\frac{du}{d\theta} = cos\theta
du = cos\theta d\theta
so sub-ing in:
\frac{cos^2 \theta}{sin\theta}d\theta
\frac{du^2 \theta}{u}d\theta
Does this look right?
Edit: No it doesn't. Should be
\frac{du^2 }{u}
\frac{du^2 }{u}
Does this Look right?
TFM
I think what rock.freak667 wanted you to get was
\frac{du}{u} \cdot \cos x = \frac{ \sqrt{1-u^2}}{u} du,
which would warrant an integration by parts.
An alternative method would be to write \cos^2 x = 1-\sin^2 x and divide through.
Could I not use double angle formula:
cos^2(\theta) = \frac{1-cos(2\theta)}{2}
Giving
\frac{1 - cos(2\theta)}{2sin(\theta)}
and then let u = cos\theta again
TFM
How would that help you? What are you going to do with the cos(2\theta) if u= cos(\theta)?
That's true, I just saw the cos squared and remebered that sometime that relation is used to break it down. So:
u = sin\theta
This gives me
\frac{cos\theta cos\theta}{sin\theta}d\theta
\frac{cos\theta }{u}du
cos\theta = \sqrt{1 - sin^2\theta}
cos\theta = \sqrt{1 - u^2}
so:
\frac{\sqrt{1 - u^2}}{u}du
So integrating by parts:
\int adb = ab - \int bda
db = u^{-1} ; u^{-2}
a = \sqrt{1 - u^2} ; da =
Does this look okay?
TFM
Well if you meant
db = u^{-1}, b = \log_e u
Then that looks fine so far in terms of correctness, though it looks like it won't be fruitful. Perhaps rock.freak667 meant something different to what i Interpreted.
Why didn't you like my suggestion though lol?
Gib Z said:
Well if you meant
Then that looks fine so far in terms of correctness, though it looks like it won't be fruitful. Perhaps rock.freak667 meant something different to what I Interpreted.
I was actually going to do
b = u^{-1}, db = u^{-2}
or is this going the wrong way?
Was your suggestion
An alternative method would be to write cos^2 x = 1-sin^2 x and divide through.
If so, should that not be
cos^2(\theta) = \frac{1-cos(2\theta)}{2} ?
I'm wondering if i have made some mistakes in actually solving the Differential Equations, since out of four DEs I have three which seem to not be able to be completed?
TFM
If I may just check my calculations.
First Question:
x(t): x' = xt + 6te^{-t^{2}}
Subtract -xt from both sides:
-xt \frac{dx}{dt} = 6te^{-t^{2}}
-x \frac{dx}{dt} = 6te^{-t^{2}}/t
-x dx = 6e^{-t^{2}} dt
Does this one look okay?
TFM
Does the above look correct?
TFM
\frac{dx}{dt}=xt+6te^{-t^2}
\frac{dx}{dt}-xt=6te^{-t^2}
Do you know how to solve first order differential equations of the form (in your case)
\frac{dx}{dt}+P(t)x=Q(t)?
That would be:
= e^Fx \int^F q(t)dt + C
F = \int p(t)dt
TFM
Sorry, Latex annoys me sometimes when editing:
F = \int p(t)dt
TFM
Lets see. So:
solution:
F = \int p(t)dt
And:
q(t) = 6te^{-t^2}
p(t) = -t
so:
F = \int -t dt = \frac{-t^2}{2}
= e^{\frac{-t^2}{2}}x \int^{\frac{-t^2}{2}}(6te^{-t^2}) dt + C
We still seem to have to integrate the e^{-x^2}? Which I thought ewas impossible?
TFM
your integrating factor of exp(-t2/2) is correct.
But your integrand should be
e^\frac{t^2}{2} 6te^{t^2}
Which can be simplified. Then you can integrating using a u substitution.
with
can you add the e values to get:
6te^{\fract{t^2}{2}+t^2}
TFM
exp(-t2/2 - t2)=exp(-3t2/2)
So we have:
e^{\frac{\t^2}{2}}\int 6te^{\frac{-3t^2}{2}}
So we have to integrate
You suggest using a u substitution
Should that be:
u = \frac{-3t^2}{2}
TFM
Yes, if u=exp(-3t2/2), What is du/dt and thus du?
So:
U = e^{-\frac{3t^2}{2}}
Would du/dt be:
\frac{du}{dt} = \frac{3}{2}^{-\frac{3t^2}{2}}
and thus:
du = \frac{3}{2}^{-\frac{3t^2}{2}} dt
TFM
