Mr.Miyagi
- 47
The problem statement
Let f:[a,b]→\mathbb{R} be differentiable and assume that f(a)=0 and \left|f'(x)\right|\leq A\left|f(x)\right|, x\in [a,b].
Show that f(x)=0,x\in [a,b].
The attempt at a solution
It was hinted at that the solution was partly as follows. Let a \leq x_0 \leq b. For all x\in [a,x_0] \left|f(x)\right|\leq (x_0-a)\underset{[a,x_0]}{\sup}\left|f'(x)\right|\leq A(x_0-a)\underset{[a,x_0]}{\sup}\left|f(x)\right|. Then we should ask what happens for A(x_0-a)<1.
The first inequality follows from the mean value theorem and the second from the given equation. When A(x_0-a)<1, then \left|f(x)\right|< \underset{[a,x_0]}{\sup}\left|f(x)\right|. I do not see how this would imply the proposed relation.
EDIT: I have already solved the next problem.
Is the series \sum^{\infty}_{n=1} \frac{x^n(1-x)}{n} uniformly convergent on [0,1]?
I suspect it is. I want to use the Weierstrass M-test, but obviously the sequence M_n=1/n doesn't work as a bound since \sum^{\infty}_{n=1} \frac{1}{n} does not converge. I can't figure how to produce a tighter bound than M_n=1/n.
