Two source circuit thevenin and norton
The discussion focuses on determining the Thevenin voltage, Thevenin resistance, and Norton current for a circuit with two current sources. The Thevenin resistance was calculated to be 7924 ohms by zeroing the sources, while the short-circuit current was found by connecting the terminals with a wire and analyzing the circuit. Node-voltage analysis was used to find the voltage at a specific node, resulting in a value of 12.14V, which contributed to calculating the short-circuit current as 0.00379 A. The Thevenin voltage can then be derived from this current, and the Norton current is equivalent to the short-circuit current. The discussion emphasizes the equivalence of Thevenin and Norton circuits in simplifying complex circuit analysis.
Fys
Can someone help me detemine The thevenin Voltage, the thevenin resistance and the Norton current of this circuit
I can't solve it cause it has two current sources
I have uploaded the picture
Thank you
what is thevenin voltage and norton current. explain to me the rules
Well, it does look like I would have to assume that both current sources are independent. With this assumption, I zero all the sources and I'll be left with the Thevenin resistance of 7924 ohms. The short-circuit current may be calculated by simply connecting the terminals on the far right with a zero-resistance wire and calculating the current through it. After doing the above, note that no current flows through the 15k Ohm resistor, so we may simply remove it, and that all the current from the 2mA source will flow through the short-circuit wire. Now all that remains is to find the current from the 3mA source flowing through the shorted terminals.
To do this, I use node-voltage analysis and assign node V1 to the top left hand corner of the circuit. After constructing the equations and solving for V1, which I got 12.14V. Using this value, I found that the current through the 6.8k Ohm reistor is 1/560 A. The short-circuit current may then be calculated by adding 2mA to 1/560 A, which gives 0.00379 A. The Thevenin voltage may be then be easily calculated. The Norton current is simply the shortcircuit current.
I'm not sure if I'm entirely correct. So could anyone double-check the above answers?
Thevenin and Norton equivalent circuits are electrically equivalent circuits whereby complex circuits may be redrawn so that they consist of only a voltage source and a resistance in series (thevenin) or a current source and resistance in parallel. By electrically equivalent I mean that replacing part of a circuit with its Thevenin or Norton equivalent will not change anything (eg. current, voltage measurements) in the circuit external to the Thevenin or Norton part of the circuit.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
