Two unknwon factors in this stoichiometry problem
To calculate the volume occupied by 36.25g of C4H10 at 85.20 kPa and 108°C, the ideal gas law (PV = nRT) is applied. The volume (V) can be isolated as V = nRT/P. To find the number of moles (n), the mass is divided by the molar weight of C4H10. The molar weight is calculated by summing the atomic weights of its components: 4 carbons (12.01 g/mol each) and 10 hydrogens (1.01 g/mol each), totaling 58.14 g/mol. Thus, 36.25g of C4H10 corresponds to approximately 0.6234 moles. It is confirmed that under the given conditions, butane is in a gaseous state, making the ideal gas law applicable.
Dooh
Can someone help me with this?
What volume, cm³, would 36.25g of
C_4H_1_0
occupy at 85.20 kPa and 108 celsius?
So I am assuming i should use the ideal gas equation, PV = nRT, and isolate V so i get:
V=\frac{nRT}{P}
heres where I am stuck, how do i solve for "n" when only the mass is given? how do i find the molecular weight?
and its my first time here .. so can some1 explain to me how these latex things work =X
Chemistry news on Phys.org
you can find the number of moles (n) by dividing the number af grams you know you have by the molar weight of the substance.
yuo can find the molar weight of the substance(grams/mole) by adding up each elements molar weight and totallying them together,
for example:
C4H10 is, 4 carbons (12.01 g/mol each) + 10 hydrogens (1.01) g/mol each) = 48.04 + 10.1 = 58.14 g/mol
and since you already know you have 36.25 g of it, that means you have,
36.25/58.14 = .6234 moles of it.
remember, the ideal gas law only works for gasses, so make sure that your butane (C4H10) is a gas under those conditions, otherwise it won't work, but I am pretty sure that at that low of a pressure and that high of a temperature, it would be.
alright tahnks i understand now
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
