How is uncertainty presented in physics?
Uncertainty in physics is often represented by the range between lower and upper bounds based on the precision of the measuring instrument. In this case, a measurement of 5.76 m suggests a range of uncertainty between 5.755 m and 5.765 m, but the measuring tool's precision limits this to 5.75 m to 5.77 m. This discrepancy highlights the importance of understanding how measurement tools affect uncertainty. Additionally, it is noted that humans can estimate measurements within 1/10th of the smallest scale, indicating a natural ability to gauge uncertainty. Overall, clarity on how to define and express uncertainty is crucial in physics.
MBBphys
If we have:
5.76 m rounded-->wouldn't the range of uncertainty be between the lower and upper bound:
5.755m - 5.765 m
However, my physics teacher said that, as the ruler you are measuring with in this scenario goes down to 0.01 m, you cannot go below that, so the range of uncertainty:
5.75m - 5.77m
Am I confusing lower/upper bound and range of uncertainty here?
N/A
N/A
I agree with your interpretation.
At university one of our lecturers told us that humans were actually quite good at estimating to within 1/10th of the smallest scale. In other words if your smallest scale is centimetres then humans are quite good at estimating to within +/- 1mm.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
