trollcast
- 13
The experiment set up is a steel ball bearing is held from an electromagnet and above a switch at the bottom. When the electromagnet is switched off a timer starts and stops when it hits the switch.
The height from the bearings initial position to the switch is measured.
These 2 measurements are then used to calculate g using the formula, $$g=\frac{2s}{t^2}$$
Which of your 2 variables uncertainties is the most significant in determining a value for g?
I said the time taken as in our equation its squared whereas the distance is only multiplied by 2 so any error in the value will be magnified more.
However the mark scheme says either is correct given a logically and scientifically correct reason.
